Turn signal relay
Old Apr 4, 2022 | 08:29 PM
Noneya's Avatar
Noneya
Turn signal relay
Folks,
A weird thing happened last week. I rented a trailer, did my thing and returned it. Afterward the left blinker indicator on the dash went on fast mode so I thought maybe a bulb or the relay failed.. Nope all lights modes (brake, hazard, turn etc.) function normally and at the correct speed. I did a search at Rock Auto for a flasher relay but no joy. Any one have a fix?
VR,
David
Old Apr 5, 2022 | 07:10 AM
BC2019F250's Avatar
BC2019F250
The flash is controlled by the BCM so their isn't a separate flasher. I would double check to make sure all bulbs are flashing.
Old Apr 5, 2022 | 07:49 AM
Ford8502's Avatar
Ford8502
Agree, with emphasis on "all bulbs" since some of the light assemblies have two bulbs and it's hard to tell that only one has failed.
Old Apr 5, 2022 | 08:57 AM
Noneya's Avatar
Noneya
Thanks for the info, I will do a deep dive into the lights.
Old Apr 5, 2022 | 10:12 AM
Noneya's Avatar
Noneya
I just did a thorough check on all lights and everything is working. I compared both sides as well. There is a flasher noise from under the hood at the firewall on the passenger side and it's the correct speed. The only two things at the "fast speed" are the dash indicator and flasher noise.
Sometimes I hate computers because my OCD is fixated on the fact I can hear the rapid flasher but can't see the turn signal.
Has anyone else experienced this?
VR,
David
Old Apr 5, 2022 | 10:17 AM
BC2019F250's Avatar
BC2019F250
I'm not sure I can help much more, but when I installed LED light bulbs in the rear brake and turn signal, the dash indicator flashed fast but the bulbs flashed at the normal speed.
Old Apr 5, 2022 | 05:13 PM
Noneya's Avatar
Noneya
Thanks for trying to help. It looks as if I will just have to get use to the rapid flashing on the driver's side.
VR,
David
Old Apr 6, 2022 | 05:06 AM
Ford8502's Avatar
Ford8502
It started after renting a trailer, so maybe there's a loose connection on a wire harness. I'd disconnect the harnesses from the trailer plugs under the rear bumper and coat them with dielectric grease. Then check the harnesses up near the spare tire and do the same to them. Both have been known to cause weird electrical issues from water intrusion or loose connections. Some have reported issues when moisture got inside their rear lights too.
Old Apr 6, 2022 | 07:57 AM
Beast2.0's Avatar
Beast2.0
Originally Posted by Noneya
Folks,
VR,
David
Is the truck showing No Trailer? Maybe try hooking another trailer up and see what happens. Cycle thru trailer settings to see if it changes.
Old Apr 12, 2025 | 03:50 PM
Ephillips's Avatar
Ephillips
4th Gear
I'm having exact same problem. 2017 XLT Powerstroke. Driver side. All bulbs flashing externally at correct interval - on/off. But in the cab the driver side indicator flashes at a fast pace. It was intermittent for several months. Now it's all the time. My case is not related to any recent trailer hook up. I'm at the point to where I'm just going to replace all the turn signal bulbs. If anyone has a better idea - would be much appreciated. Thx
jaym69
2009 - 2014 F150
Jul 24, 2023 12:14 PM
OldseabeeIdaho
Apr 23, 2023 02:19 PM
R&T Babich
Feb 21, 2017 07:10 PM
perljammike
Dec 25, 2012 04:59 PM
lexasgs400
Oct 26, 2007 12:11 PM
