Air Bag Light Stays On?
Old Feb 11, 2022 | 08:16 PM
1L243's Avatar
1L243
On my 1999 F250 my air bag light is staying on. It flashes once then five more times several times then stays on .
From what I have found that is telling me it's code 15. I have seen several error codes in research with code 27 being one of the most common.
My passenger air bag light is working and it does cycle and go out.
I should say recently I added power heated mirrors and tapped into wires under the dash for running light, left and right turn and a power directly do the fuse panel fuse 27 for customer access.
I tested the wires I tapped into for running, left and right turn and they were the correct wires.
I checked the fuses in the fuse panels related to the air bags and they are good.?
Old Feb 12, 2022 | 10:03 AM
Walleye Hunter's Avatar
Walleye Hunter
No ideas here and don't recall ever seeing a post regarding the air bag but here's a bump for ya.
Old Feb 12, 2022 | 10:48 AM
bsiliani's Avatar
bsiliani
This may be dumb, but did you check under the driver's seat to see if your AIRBAG electrical connection is secure and connected properly ?
If you somehow disconnected that connection directly under the driver's seat, your air bag light will stay on. Ask me how I know.
Old Feb 12, 2022 | 11:20 AM
BWST's Avatar
BWST
Got Data?
Do you get any other codes when you read them with a scanner? There might be some "Bxxxx" codes that can help guide us in addition to that code 15 from the airbag light itself.
From a post out of the thread below:
DTC: Diagnostic trouble code, retrieved using scan tool.
LFC: Lamp fault code, flashed on air bag indicator.
Tone will sound only if additional DTCs are present
Here are the airbag codes
LFC
DTC-----LFC-----PRIORITY-------DESCRIPTION
B1231---19----------3-----------RCM Crash Data Memory Full
B1342---24----------2-----------RCM is Faulted
B1869---Tone c------—
B1870---Tone c------—
B1871---25 ---------14----------Passenger Air Bag Deactivation (PAD) Switch/Module Fault
B1877---46----------24----------Driver Pretensioner Circuit Resistance High
B1878---17----------26----------Driver Pretensioner Circuit Shorted to Battery or Ignition
B1879---17----------26----------Driver Pretensioner Circuit Shorted to Ground
B1881---47----------25----------Passenger Pretensioner Circuit Resistance High
B1882---18----------27----------Passenger Pretensioner Circuit Shorted to Battery or Ignition
B1883---18----------27----------Passenger Pretensioner Circuit Shorted to Ground
B1884---27----------15----------Passenger Air Bag Deactivation (PAD) Lamp Inoperative
B1885---46----------24----------Driver Pretensioner Circuit Resistance Low
B1886---47----------25----------Passenger Pretensioner Circuit Resistance Low
B1887---15-----------6----------Driver Air Bag Circuit Shorted to Ground
B1888---16-----------7----------Passenger Air Bag Circuit Shorted to Ground
B1890---27-----------15---------Passenger Air Bag Deactivation (PAD) Warning Lamp Shorted To Ground
B1891---—-----------------------Air Bag Tone Warning Indicator Circuit Shorted to Battery or Ignition
B1892---—------------—---------Air Bag Tone Warning Indicator Circuit Shorted to Ground or Open
B1916---15------------6----------Driver Air Bag Circuit Shorted to Battery or Ignition
B1921---21------------4----------RCM Bracket Ground Resistance High
B1925---16------------7----------Passenger Air Bag Circuit Shorted to Battery or Ignition
B1932---32------------8----------Driver Air Bag Circuit Resistance High
B1933---33------------9----------Passenger Air Bag Circuit Resistance High
B1934---34------------10---------Driver Air Bag Circuit Resistance Low
B1935---35------------11---------Passenger Air Bag Circuit Resistance Low
C1414---29------------5----------Incorrect Vehicle ID
----------------------------------No Communication with the Restraints Control Module (RCM)
https://www.ford-trucks.com/forums/4...-stays-on.html
Old Feb 12, 2022 | 01:01 PM
1L243's Avatar
1L243
I checked all the plugs under the drivers seat with no results. Also rechecked the fuses related to the airbag with no results. I removed the heated mirror wire to fuse #27 in the panel with no results.
When I tapped into the main wire harness under the dash according to the Mirror installation instructions I had to remove some factory tape around the harness. After tapping the wires I re-wrapped the harness.. I removed the tape to check the wires I added and gave the wires a little more room. Success! Light is out. All I can think of although I can't see anything maybe when I removed the factory tape I nicked something?
I'm going to leave the 6 inch area where I removed the harness tape free for now.
If problem flares up again I may have to go back in there and examine the wire harness more closely.
Old Feb 12, 2022 | 09:16 PM
RA101725's Avatar
RA101725
Banned
I've often wondered what the shelf life is on those airbags and if I should be expecting it to either fail to work in a collision or blow up in my face while going down the road. Almost tempting to remove it and not have to wonder any more.
Old Feb 13, 2022 | 02:49 AM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
Glad you got it sorted!
Old Feb 13, 2022 | 09:12 AM
Walleye Hunter
That is a good question, I never heard anything on a shelf life for them. FYI, the 'air bags' are activated with an explosion. There is some sort of explosive container in there that gets lit up when activated by a sensor somewhere up on the bumper. Also FYI, primers and ammo don't seem to have any shelf life restrictions if they're kept dry.
waters1269
Dec 21, 2011 06:30 PM
mandbcards
Dec 27, 2007 05:34 PM
mvlr5000
Aerostar
Nov 3, 2002 10:10 AM
mholota
May 6, 2000 09:21 AM
