2005 F-250 6.0 Crank, No Start
I’ve got an 05 F-250 with the 6.0, approx 201k on it. I just purchased the truck about 6 months ago and it was running pretty well. Cold starts were slightly troublesome when the temps got below 50 but nothing too bad. The motor didn’t appear to have had a whole lot of work done to it so I decided to be a little proactive and do head gaskets, studs, oil cooler, and EGR cooler. Here’s the low down on what’s happened: Replaced Head Gaskets, EGR Cooler, Oil Cooler, Installed Head Studs
Crank, No start after re-assembly
Checked IPR filter screen, not very dirty
Found Cam Sensor Connector corroded, replaced connector
Started - injector knock, cylinder 1 underperform, significant white smoke
Replaced fuel injector in cylinder 1
Same results, injector knock, cylinder 1 underperform, significant white smoke
Installed new injector wiring harness and new FICM power board (Dorman)
Crank, No start
Reinstalled original FICM power board
Crank, No start
Load tested batteries, found bad. Replaced both with new Interstate Battery - Group 65, 850cca
Crank, No start
Replaced FICM relay
Crank, No start
FICM Main Power, 48-48.5VDC; FICM Logic Power, 12VDC; ICP during crank, 2000+ psi; IPR at crank, 84.7 - decreasing as ICP rises
Crank, no start
Installed new remanufactured FICM
Crank, No start, same values as above, no injector clatter at key on
Crank, No start, same values as above, does have injector clatter at key on
Crank began to weaken, put batteries on charger, but charger wasn’t charging.
Took batteries and alternator to be tested, both clean.
Reinstalled batteries and alternator
Starter click only.
Replaced starter, put batteries on charger and charged appropriately
Crank, No start.
Check voltage at injector plug, 48VDC pulses
Crank, No start
FICM Logic Power: 12.4; FICM Main Power: 48.5; ICP: 2000+ psi after cranking for a few seconds; IPR: 14.7 pre crank, 84.7 at initial crank, decreasing to 47 during crank; FICM sync: 1; Slight smoke out tailpipe after cranking for a bit.
Crank, No start
Replaced both fuel filters
Crank, No start
No codes stored or pending
I’m open to any suggestions at this point. It’ll fire off with some ether but doesn’t stay running. Thanks!
yeah I get sync and FICM sync during crank. Haven’t scanned for codes while cranking, but will once I get my cable in for ForScan. Just using a scangauge2 right now.
I’ve check fuel pressure at the bowl on top but just by letting it fill with the cap off. It’s fills pretty quickly.
