New guy needs help with his Ambulance
I'm new to the site as well as new to our recently purchased 2002 E350 7.3L Super Duty 4WD Turbo Diesel with Ambulance package. Heck, I didn't know what any of those words really meant until a few weeks ago.
I've been a VW Vanagon guy my whole life and am comfortable with engine and trans swaps but this diesel is all new territory for me.
I purchased the van from the hospital I work at and then came across this forum while doing some research on how to get it road worthy and its been a great resource!
One of the main reasons the van was sold was because it kept eating up batteries. According to the maintenance records it was taken to a shop for diagnosis. It didn't throw any codes but they said "there was an open circuit somewhere".
I've read that the alternators are the usual culprits so while I waited for my new battery to arrive I pulled the cables off the rear house bank and removed each alternator and performed a diode check. Unfortunately both passed. (That would have been too easy!) I think the next step will be to install the new battery tomorrow and go thru the fuse box under the hood and see if there is a parasitic draw I can track down.
If I don't find anything obvious from the fuse check where should I look next? Is there a test I can perform on the PCM/IDM? Are there any "Usual Suspects" I should know about with these vehicle?
Oh, and who makes the best/preferred Repair Manual for these vans?
Thanks!
es) and pull all the fuses then put them back in one by one until you find something. I don't know how vans are set up but if it has a split in the power line or two fuse boxes, you can cut your chase a little shorter by splitting them and seeing which one is the culprit.
I don’t have anything good to offer but I’ll throw some thoughts out anyhow.
Maybe start by pulling the battery cables and doing a multimeter check to see how much draw it has. Might give you some type of clue.
From there you could disconnect the alternators to see if the draw goes away. Seems I’ve also read of some complicated issues with dual alternators.
A couple other things easy to check would be removing the hot wire from the glow plug and IAH relays.
Good luck! The guys around here are really good at helping solve issues. And also good at spending other people’s money!
https://ceautoelectricsupply.com/pro...ry-cable-kits/
They also have a charging system upgrade kit that is semi-custom and not listed on the website.
The guys here on this forum are like no other.
Be patient and careful about blindly throwing parts at a problem.
Larry
welcome to the forum
Hahaha! Yes!
Thanks all for the warm welcome!
I was distracted today with adding the flu and chimney to our Dwarf wood stove in the Airstream but tomorrow is Gremlin Diagnostic Day!
I'll be sure to take a pic of the fuse box before I tear into it. And that Forscan app/dongle seems like a great assessment tool! I'll keep an eye out for hotter than normal accessories and methodically try to work thru each system.
T-wood- The driver's seat has a large manual toggle switch mounted to it that isolates the rear bank of batteries which is what I think saved them from whatever is going on in the "front" of the ambulance. When the engine battery was dead I could throw that switch and start the truck with the rear bank.. of which I think there are three in that diamond plated box on the driver's side in the picture.
bigb56- That's a good point about short trips around town. Graeagle is no metropolis and a lot of the "calls" were around town. I'll look into the Victron Smart Shunt to keep an eye on charging.
Is there a download of the Repair Manual somewhere on the forum I didn't see yet? I was going to pick up a Haynes or such unless there is another author everyone prefers?
Ford Service Manual? - Page 19 - Ford Truck Enthusiasts Forums (ford-trucks.com)
The house battery setup might be particular to the shop that did the ambulance conversion. Maybe they have info. Any door jamb stickers to get the name of the shop?
Or hey, go to whoever maintained the van for the hospital, maybe they have documentation. Possibly even the purchasing dept that bought it new. Might get lucky and find someone willing to dig thru old files.
After spending the day with my trusty multi-meter and checking the battery banks, dual alternators and the charging system I've found the drain and its is simpler than I hoped.
I was getting a substantial draw and after isolating the "front" of the ambulance from any parasitic drains I moved onto the wiring nightmare in the business end of the rig and located a very faint humming noise behind an access panel when the engine was off. I knew there was an inverter in the back but didn't think it was constantly hot. Whomever replaced it never included an On/Off switch so it ran constantly and would drain the batteries. I won't be using it for my purposes so I unplugged it and all is right in the world.
Thanks all for your input. It really helped me get acquainted with these motors and this setup.
Now that its running I'm going to dive into some mods to try and squeeze some more power out of this pig. But I'll start a new thread for that..
There is always a learning curve when acquiring a new to you vehicle. I am glad you are resourceful enough to sort things out yourself instead of paying someone $150 an hour to figure it out for you.
