Sponsored by: Real Truck
no overdrive od off light on
Old Oct 21, 2021 | 09:20 PM
Dreim's Avatar
Dreim
4wd Low
Hi Hoping some one out her can help I have an 02 f350 7.3 4x4 163k truck runs great put won't go into overdrive the od off light stays on all the time tried swapping it out with one i know works still stays on weather you press the button or not shifts smoth in every gear no slipping i feel three shifts 1 to 2 2 to 3 then lockup im guessing anyone run across this problem before any help would be greatly appreciated
Old Oct 22, 2021 | 06:57 AM
99powerstrokedF250's Avatar
99powerstrokedF250
It kinda sounds like you have an issue with the OD off circuit. If I recall, there were some issues with that shifter in that, over time, the wires for the OD off switch could suffer abrasion. If they have worn through to bare wires then it won't matter if you press the switch or not, the light will come on and it will be permanently locked out of OD. IF this is your issue (and I'd want to do some continuity testing before replacing any parts), I think the only real solution is to replace the shifter stalk.
Old Oct 22, 2021 | 07:19 AM
lshort's Avatar
lshort
Have you put a scanner on it? The OD is disabled when there are transmission codes. But I think the OD light would be flashing.
Dreim's Avatar
Dreim
4wd Low
I did replace the entire shifter stalk did a voltage test I had 12v at the red wire and 2.4v on the green one I believe it was so everything checks out there
Old Oct 22, 2021 | 07:22 AM
Dreim's Avatar
Dreim
4wd Low
I have put a scanner on it I have no codes coming up
Old Oct 22, 2021 | 07:21 PM
Dreim's Avatar
Dreim
4wd Low
So I borrowed a snap on scanner and came up with a p1780 transmission switch out of self test range could I be looking at a problem with the wire harness that plugs into the transmission or possibly in the oil pan anyone experience this before
Old Oct 22, 2021 | 09:08 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
P1780 will set if you didn't cycle the switch while self test is running, or if the switch or wiring is bad.
Old Oct 23, 2021 | 02:51 PM
Dreim's Avatar
Dreim
4wd Low
I did cycle the switch I replaced the the shifter and the wiring and still getting the code and my od off light is still on constantly
Old Oct 23, 2021 | 04:40 PM
Mark Kovalsky
Did you replace the wiring all the way from the switch to the PCM? If not, then you still have a problem with the wiring between the switch and the PCM. Or a faulty PCM, but that is less likely than a wiring issue.
Old Oct 23, 2021 | 05:30 PM
Dreim's Avatar
Dreim
4wd Low
I have not replaced all the wiring but I checked the voltage and I have power where it needs to be
Old Oct 23, 2021 | 07:57 PM
Mark Kovalsky
Great. Do any of the wires to the shifter have a short to ground?
Old Oct 23, 2021 | 09:08 PM
Dreim's Avatar
Dreim
4wd Low
Not that I have found I've checked everything shy of cutting the loom and going back to the pcm
Old Oct 24, 2021 | 08:37 AM
Mark Kovalsky
Why would you cut the loom? Looking at the wires is not a good way to see if it's good. If all you've done is look at the wires, you haven't determined if the wires are good or bad.
Unplug the harness from the PCM and the shift handle. Probe the BACK of each connector and check for continuity in each circuit, and from each circuit to power and to ground. That will determine if you have a wire broken inside the insulation or a short to power or ground anywhere in the circuit. Anything less than that is just guessing.
Old Oct 24, 2021 | 08:50 AM
Djosbun's Avatar
Djosbun
Checking for voltage isn't the best way to test wiring. You might read 12 V but not have enough current. You need to load the wire (typically with a test light) in order to have accurate results.
-- Dave
Old Oct 24, 2021 | 09:45 AM
Mark Kovalsky
Checking continuity is far better than checking with a test light.
