239 flathead bearing check
Old Oct 5, 2021 | 10:11 PM
cro-magnon's Avatar
cro-magnon
4wd Low
hi folks id like to check out the rod & mains on a 1BA 239 (on a stand) i have enough experience on chevy engines etc. so no problem wrenching so when i pull the caps are there any surprise's i should be aware of? i have a flathead rebuild book for the torques >>> thanks in advance<<<
Old Oct 6, 2021 | 10:44 AM
f5fordgirl's Avatar
f5fordgirl
You mean like ball bearings and springs jumping out?
Old Oct 6, 2021 | 12:35 PM
cro-magnon's Avatar
cro-magnon
4wd Low
no im looking for a little more intelligent answer like dont loosen the out board main its better to do an inboard main for inspection or when you remove a rod cap make sure its position is @ BDC to keep these bearings in line something intelligent like "you got this its no different than a SBC so thanks for the insult but ill pass on ball bearings shooting on the floor
Old Nov 10, 2021 | 02:15 PM
artscott61's Avatar
artscott61
Veteran: Navy
Cro Magnon I would go over to the 48 /56 ford trucks and ask ALBUQ-F-1. He works on flat heads all the time and would give you an honest answer. Good Luck.
thundersnow70
Jan 30, 2017 08:20 PM
Argess
13
Oct 16, 2010 12:03 PM
79_250RangerLariat
Jul 12, 2006 03:19 PM
redf1001962
Apr 4, 2006 07:28 AM
78 Ranger
Feb 19, 2006 03:14 PM
