2001 F350 7.3 4X4 GEM/Fuse block interchangeability?
Old Sep 26, 2021 | 06:55 PM
Dalton gang's Avatar
Dalton gang
4wd Low
Question 2001 F350 7.3 4X4 GEM/Fuse block interchangeability?
Having major issues with this and am trying to figure out if other (similar) part numbers will work as a replacement.
Most of the replacements I'm finding have a different prefix and or suffix on the part number.
Also some places I am getting info from are claiming that I will need to reprogram the replacement parts.
Anyone here have experience with this?
Any advice on where to go for a reasonably priced replacement with no BS?
Thanks
Old Sep 26, 2021 | 07:25 PM
kbeefy's Avatar
kbeefy
I think as long as it's from a Diesel it will work. Theres a design split, maybe '02.
As far as programing, I believe it's only for a few higher end options, the truck will still run without programing.
If I remember correctly, the suffix (AB and EB on the ones pictured) are updates of the original part. Most of them are interchangeable.
Everything before that has to match.
Old Sep 26, 2021 | 07:30 PM
ESwift's Avatar
ESwift
CNCFAB
I have a spare one on a shelf from an e99Let me see what label says in the morning.
Old Sep 27, 2021 | 07:35 AM
RigCity's Avatar
RigCity
Usually the last 2 numbers/digits when changed indicate a part update. Are you changing the fuse box as well or just the GEM? I’d recommend a thorough leak and water intrusion inspection this is a known failure part from water leaking in past the windshield. You can start the repair with a hammer if there’s water entering the cab.
Old Sep 27, 2021 | 08:25 AM
brian42's Avatar
brian42
Veteran: Navy
If you get a replacement GEM you will have to get a dealership to program it to your truck.
Old Sep 27, 2021 | 02:38 PM
Prototypemech's Avatar
Prototypemech
Why do they need to reprogram it? AFAIK, the GEM doesnt include any security features... it just runs the windows, lights, window wipers and door locks.
Old Sep 27, 2021 | 04:18 PM
Dalton gang
4wd Low
I will be replacing both
Old Sep 27, 2021 | 05:45 PM
ESwift's Avatar
ESwift
CNCFAB
I know a guy with a used one off an e99
elkvis
Jan 7, 2019 02:41 PM
gtmustang00
Jan 30, 2016 03:18 PM
Tank77
15
Jun 20, 2015 02:03 PM
Stephan B.
Dec 3, 2011 07:42 AM
