Need Synchronizers for New Process 210 overdrive transmission
Both synchronizers removed from gear
Does anyone have for sale or know where i can look for Synchronizers for New Process 210 Transmission???. Transmission came out of my 1955 f600 that I am restoring. Anyone know of any old transmission Parts suppliers that may have some Synchronizers for this transmission???. I prefer to buy new set to finish the rebuild on my transmission but good used ones will work.! Synchronizers from any new process may work!! . Also could use good input shaft for the transmission and FYI it has 21 teeth verses the direct drive 19. I have a New Process 210 direct drive transmission and a New Process overdrive transmission that are both in need of a set of synchronizers and these synchronizers are the same so they can be interchanged!! So i am curious if other New Process transmissions have the same synchronizers. If i cant find synchros IMay be in the market for a good transmission that will fit my truck. Distance between the pins
transmission that will fit my truck!
Reason: I discovered the part had two different part numbers but both the direct and overdrive synchros can be interchanged and wanted to add photos to opening message
Great source for parts. I didnt see what I was looking for on their pdf catalog . I will call and ask if they have any source for Transmission parst or different transmission that will work! Thanks Abe!!!
I have a overdrive 210 here out of a 55 f600 I’d sell. It was a running driving truck then water got inside the trans. Now it won’t shift. But I’d bet there would be good parts to be had still inside. Send me a PM if interested
I dont know how to send a pm yet but I am interested in maybe buying your transmission for possible parts. Thank you for the offer and your help! You may be the only chance at getting this transmission going again..SO far I havent had any luck at all. I better look for a few more weeks and hope i find a set of new synchronizers and maybe an input shaft. Thanks again
