94 300 to 75 302 swap
Old Mar 12, 2021 | 02:52 AM
Colin1Blevins's Avatar
Colin1Blevins
i’m swapping my blown 300 out of 94 f150 for a 75 302 out of a mustang ii
i have a couple questions regarding the swap
what engine perches do i need. are all 302 perches compatible or do i need a specific year
i know i will probably need a rear sump unless the front will fit (it fit in the 65 f100 it was in)
the truck will be carb
my biggest concerns is the sump and the engine perches. after i get that info i think i can manage the swap lol but any advice is welcome and appreciated
Old Mar 12, 2021 | 08:26 AM
jas88's Avatar
jas88
Yes you will need rear sump pan. You can use perches from an OBS truck with 302, just use the same year motor mounts.
Old Mar 12, 2021 | 08:36 AM
rla2005's Avatar
rla2005
Why on earth would you swap in a V8 that makes less horsepower and torque than the current 4.9L 6 cylinder currently in the truck? You picked probably the worst vintage V8 for your proposed swap.
Old Mar 12, 2021 | 04:23 PM
Mikulh's Avatar
Mikulh
Here's a screenshot I saved from a few years back when I was looking for engine supports to swap a 351 (same mounts as 302) into my '91.
BroncoGraveyard.com carries these now.
https://shop.broncograveyard.com/Mot...uctinfo/30500/
Old Mar 13, 2021 | 12:49 PM
NotEnoughTrucks2014's Avatar
NotEnoughTrucks2014
I'd have to agree, but normally I would endorse any excuse to replace that overhyped 6 banger with a V8.
Anyways, around 1980, Ford changed the oil dipstick location from the pan to the block. You will find that with the later pan on the earlier block, you may not have a location for the dipstick.
Also, if you plan to go carbed, I sure hope you have a manual transmission. The AT's used in 94 are electronically controlled which means you need all those sensors not only for EFI, but also for transmission control. Taking out the EFI engine, (or components) will result in an undriveable truck unless you opt for a fairly expensive stand alone transmission controller.
Lastly, how to you plan to accomodate the high pressure fuel system provided by the in tank pumps in your 94? You need to control the pumps safely, (a function provided by the ECM) and you need to bring the pressure down to carburetor friendly levels. That can be a pretty disastrous project and fuel pressure regulators are not the best choice. Swapping to earlier tanks without in tank pumps and using the mechanical pump on the engine would be the safest route.
Best solution would be to swap in a later EFI 5.0 or 5.8.
Old Mar 13, 2021 | 05:49 PM
Colin1Blevins
thanks anyway but no. the truck has a m5od and i have 74 f100 tank under bed so the fuel pump on motor will be just fine but thanks for the un needed input. i asked about engine perches.....
Old Mar 13, 2021 | 05:51 PM
Colin1Blevins
motor is not stock... it was in a 65 f100 and did just fine and the pos 300 can go to the garbage where it belongs so thanks for the un needed input also but i asked a question about engine perches)))
Old Mar 13, 2021 | 06:01 PM
Colin1Blevins
my next and last question would be what is the compatibility of rear sump pans. prefer one with the oil pan dipstick but can modify if needed but would like to avoid. thanks for answering my previous question without any bs
Old Mar 13, 2021 | 08:15 PM
NotEnoughTrucks2014
Obviously not. Good luck anyways.
Old Mar 13, 2021 | 08:17 PM
Colin1Blevins
any advice on the question i asked. obviously you had no help therefore you could’ve saved the time and not said anything because guess what.... i could care less what you think... but hey thanks for the “luck”
flip418
Nov 7, 2016 08:24 AM
dusterfanatic
Oct 1, 2012 12:00 PM
wolfe1104
Engine Swaps
Oct 17, 2004 02:35 PM
mdo
1978 - 1996 Big Bronco
Feb 23, 2000 01:45 AM
