Looking to EGR / DEF delete on 2012 F250
Old Sep 30, 2020 | 04:34 PM
FlaMtnBkr's Avatar
FlaMtnBkr
2nd Gear
I'm the original owner with 45k miles and starting to get "restricted" or "low flow" EGR codes and I'm assuming the cooler is clogged with soot. So looking to get rid of it all but not sure what is available these days? Would like to keep it stock as possible and use blocker plates and keep as much of original exhaust as possible. What are the best options currently available? I've tried reading but a lot of threads are old and I have no experience with any of this.
Thanks!
Old Oct 1, 2020 | 09:15 AM
Just Strokin's Avatar
Just Strokin
Not sure you are going to find much on a "delete" kit of any sorts now days. Even if you can delete the EGR by itself, you would need a tuner that are getting hard to find much less people writing tunes.
You can pull the cooler and "rebuild" it. Ford and Dorman makes the parts to replace the cooler core.
here are a couple vids on the cooler
Old Oct 2, 2020 | 05:37 AM
Overkill2's Avatar
Overkill2
With the EPA being ***** out against the delete manufacturers and software writers, you have to find the friend of a friend as all the shops went further underground.
Like Larry said, replace the cooler core. Bullet Proof Diesel makes a redesigned EGR cooler that I believe has a lifetime warranty on it and is redesigned to provide a long clog free life. It's not cheap but might be the ticket for you if you can't delete. Just throwing it out there for FYI.
skinner2008
Mar 6, 2020 09:28 AM
Poorboy04
Apr 22, 2013 08:05 PM
smoore0531
Dec 18, 2012 10:35 AM
fordmudman
Jan 16, 2011 02:44 PM
uscghutch
Jun 23, 2007 04:55 AM
