2017 F-250 DEF TANK HEATER
Old Sep 29, 2020 | 11:49 AM
PaulV78's Avatar
PaulV78
My F250 just hit 85K miles and the check engine light came on. I was towing a boat and the speed was limited, cruise control wouldn't hold speed and a exhaust filter indicator went on.
Shortly after the DEF indicator did the countdown and then disappeared at about 200 miles left.
Check engine is still on and local dealership says the DEF heater went and the tank needs to be replaced.
Almost $1800.00 repair seems ridiculous for something like this?
Any thoughts?
Old Sep 29, 2020 | 03:05 PM
senix's Avatar
senix
If you have ford pass, check to see if you are still under warrenty for the def heater, several are.
You can also replace it yourself for a lot less. This is not an $1800 repair. The part alone is not that much and all that is needed is to drop the def tank.
I'd imagine 2 hours labor.
Old Sep 29, 2020 | 06:12 PM
dirthawg's Avatar
dirthawg
The 17 version is twice that of the 11-16's.......still not $1800 worth. And why are dealers suggesting an entire assembly replacement? Are they lazy and don't want to disassemble the heater or maybe they are being proactive that the pump is going fail next? Adding all the component costs together for that model is less than $900
https://parts.autonationfordwhitebea...ump-hc3z5j229b
Old Sep 30, 2020 | 06:59 AM
kper05's Avatar
kper05
I thought $900 was ridiculous when mine failed...
Old Sep 30, 2020 | 08:05 AM
tradosaurus's Avatar
tradosaurus
$1800? Time for a delete.
slownsy
Sep 15, 2020 01:16 PM
coolemoff1
Feb 21, 2018 06:58 PM
tbruz
Nov 13, 2015 08:45 PM
my02ctd
1997 - 2003 F150
Dec 10, 2013 06:45 PM
crowex
6.7L Power Stroke Diesel
Jan 5, 2012 05:51 PM
