Turbo 'whine'?
Old Sep 21, 2020 | 11:23 PM
Alaskan_Warbird's Avatar
Alaskan_Warbird
Turbo 'whine'?
Is it normal for the turbo to kind of whine sometimes, between 20-30psi? Drove around with the radio off today and noticed it.
Old Sep 22, 2020 | 07:17 AM
Pugga's Avatar
Pugga
Check the clamps on the hot side pipe. One of mine was apparently loose enough to let out some of the pressure and would make an interesting noise, somewhere between a whine and the high pitched sound you can make with a balloon by letting the air out and distorting the air fill. Might not be your issue but it's a simple place to start. It was also apparent this was happening because the oil that was in my hit side pipe left a nice mist mark where it was blowing by the factory clamp. I had to tighten them to the point I didn't think the factory worm drive clamps would take but they did seal up and the noise went away. It was only happening initially when the boost gauge crept over 20 psi.
Old Sep 22, 2020 | 12:54 PM
Alaskan_Warbird
Thanks! I'll check it out.
Old Sep 22, 2020 | 08:08 PM
senix's Avatar
senix
mine only makes some sound when towing and using the exhaust brake, otherwise I don't hear it.
Old Sep 22, 2020 | 09:29 PM
Alaskan_Warbird
Thanks. For clarification, it's whining somewhere between 15-25 psi. Hard to tell on the digital gauge.
Old Sep 23, 2020 | 06:51 PM
ssunit1's Avatar
ssunit1
Never noticed that sound in either my ‘15 or ‘18. Thought that sound came out the exhaust pipe and stoped when the makers added all that DEF crap.
Old Feb 17, 2025 | 07:57 AM
JoeUser's Avatar
JoeUser
Apologies for reviving this old thread, as I was searching for possible causes for the turbo whine I'm experiencing when cold. I appreciate the suggestion for checking the hot side pipe clamps, and hope that my whine is due to that reason (since I recently replaced my hot side pipe with an aftermarket model).
I'll double-check the clamps, especially the ones closest to the turbo (since they were a PIA to reach and tighten).
Edit: The whine I was hearing in the cab ceased after I retightened the hot side clamps nearest to the turbo. I guess that the rubber and metal was affected by the cold temperatures, allowing some leakage. Makes sense, since after fully warming up the engine it abated dramatically. Now, even when cold there's no longer any noise.
custom_nirvana
Jan 28, 2008 09:24 AM
ktplotts
May 10, 2005 12:05 PM
