6r140 transmission trans fluid leak from bellhousing
Old Sep 18, 2020 | 11:01 PM
dothedew192's Avatar
dothedew192
Hey everyone, just looking for some insight as my search for information has come up fruitless. I have a 2011 that has developed a fluid leak coming from the bellhousing area. Its losing roughly a quart every three weeks or so and I'd like to pull it and fix whatever is wrong. We've rebuilt plenty of transmissions along the way, have my own shop and tools and what not but have been out of the business for a while. So ordinarily I'd say this is a classic front pump seal leak but my knowledge of the 6r140 is non existent aside from what I've researched online. Does this transmission use a usual seal upfront or is there something special about this one? Any and all tips, tricks and advice would be greatly appreciated.
Old Sep 20, 2020 | 10:21 PM
Iowa Ford's Avatar
Iowa Ford
My Dad's 14 had the same problem about two years from new.
it was the vent on top of the transmission that caused the front pump seal to leak.
He only towed heavy with this truck and in to the heat of the south.
So be sure you look at that while you have the transmission down.
I'm not 100 % sure but I think there were some changes in the vent tube design over the years.
I researched his problem here and came up empty too.
Good luck.
Old Sep 21, 2020 | 04:42 AM
buba 11's Avatar
buba 11
FYI, youtube has some videos on the 6r140. think I saw one on the vent tube, another on disassembly.
Old Sep 21, 2020 | 09:05 PM
dothedew192
Hmm, interesting. Well I've ordered the seal and while I have it dropped I will definitely investigate the vent tube. I will do some more research to see the changes, and also try to learn why it was changed or even if it's just the location of where it sits that is different. Thanks for the reply! I appreciate it!
Old Sep 21, 2020 | 09:14 PM
dothedew192
Thanks for the other reply too! I've scoured youtube on the 6r140, disassembly videos and all and they all skip on the front seal from what I've found. A few don't even mention vent tubes lol Google search comes up with nothing, and I have watched four disassembly videos now on it, but no mention of what exactly they use for a seal. But to be continued. I will order the seal from ford and ask them about it and also if there is a revised vent tube or what they know about it and will post back up when the operation is done and complete.
Old Sep 22, 2020 | 12:55 AM
kper05's Avatar
kper05
I haven't had a need to try the 72 hours subscription yet but I would think the workshop manuals would discuss this.
https://www.motorcraftservice.com/Home/Pricing/7
Old Sep 23, 2020 | 05:37 AM
buba 11's Avatar
buba 11
I haven't worked on an automatic in around 25+ years and back then that was C4 and C6's, that being said, leaky seals sometimes meant worn torque converter - front pump bushing or flywheel issues. Anyway something to check for, of course, is is likely just a bad seal. Just trying to help a fellow Ford owner.
Best luck.
SA
rews2
Mar 19, 2015 05:23 PM
10bands
Aug 13, 2007 03:43 PM
fordf150offroad
Mar 22, 2006 07:52 PM
Mudder
Bronco II
Jun 21, 2005 12:15 AM
51truck
Aug 30, 2002 05:20 PM
