7.3L / 6.8L V8 Gasoline Engines Discuss the new 7.3 and 6.8L Gasoline V8s
Fumoto valve
Old Jun 21, 2020 | 09:28 PM
alumizilla's Avatar
alumizilla
Fumoto valve
Looking to see if there’s a Fumoto oil drain valve that works on the 7.3. Search only turned up one that did not work.
Old Jul 10, 2020 | 10:54 AM
OffBalance's Avatar
OffBalance
If you know or can measure your oil plug thread size (and depth) you can find one in the chart here: Find Fumoto® Products | Fumoto® Engine Oil Drain Valves. Or call their 800 number: (800) 918-3406. Since presumably a lot of fleets will run this engine, I expect Fumoto will make sure there is a valve that fits. Why did the one you found not work?
Please let us know when you find out; this will be one of my first mods when I get my truck.
Old Jul 20, 2020 | 11:03 PM
fender1325's Avatar
fender1325
So, school me on what a fumoto valve is. To me, it's an unsafe and unnecessary convenience to add any kind of quick release valve on your oil pan. If it accidentally pops open while going down the road, there goes your oil and your engine.
Old Jul 20, 2020 | 11:16 PM
OffBalance's Avatar
OffBalance
It is indeed a quick release valve, but one that is designed to not pop open under even extreme conditions. And they even offer a special lock if you are concerned about it. They're used largely by fleets, including semi trucks.
Maybe someday they'll offer quick release oil filters also? LOL
Old Jul 27, 2020 | 06:16 PM
OffBalance's Avatar
OffBalance
I emailed fumoto support and they sent me this:
Thank you for contacting us.
Here is the link to our retail store where you can find all the options available for your F-250:
https://www.fumotooildrainvalve.com/...modelId=654219
Here is the link to our retail store where you can find all the options available for your F-350:
https://www.fumotooildrainvalve.com/...modelId=654222
If you need help choosing the best style for your specific needs click here:
https://help.fumotooildrainvalve.com...-these-valves-
If you have any other questions or need further assistance please let us know.Thank you for choosing Fumoto!
I'm surprised the valves have different threads on the F250 (14mm-1.5) and F350 (12mm-1.75). That doesn't make sense to me. Do they have different oil pans?
Old Sep 6, 2020 | 03:07 PM
alumizilla's Avatar
alumizilla
This post is referencing the one that someone tried and it did not fit:
https://www.ford-trucks.com/forums/1...l#post19171728
It was a F106SX which shows up on the links in the previous post as working with the 7.3L on an F250.
Can anyone confirm they have ordered one that fits correctly? If so, what is the part number? Thanks!
Old Oct 18, 2020 | 12:34 AM
JayCarver's Avatar
JayCarver
Bumping this tread to see if anyone has this figured out for the 7.3?
Old Oct 18, 2020 | 11:34 PM
AUTOHAUL's Avatar
AUTOHAUL
Last March I ordered a F106SX for my F350 DRW 7.3L and it didn't fit. I sent it back and ordered a F107SX. I haven't installed it yet but should be the one. I can't believe ford would put a different pan on the same engine my guess is that Fumoto hasn't updated the F250 yet.
Old Oct 23, 2020 | 09:37 PM
JayCarver's Avatar
JayCarver
Thanks Sir, I ordered a 107.
This seems like as good a place as any to ask...
Anyone have the part number for the oil filter?
The idea of calling this motor a 7.3 seemed great until you go looking for parts... EVERYTHING comes up for a 7.3 diesel even when you type in GAS 7.3.
Old Oct 27, 2020 | 01:37 PM
wizardsr's Avatar
wizardsr
According to the manual, tried and true FL820S
Old Oct 27, 2020 | 05:34 PM
wiskeyVI's Avatar
wiskeyVI
I use them on all the cars I've had for the lats 12yrs.
Never an issue and very clean to use.
Old Oct 29, 2020 | 05:20 PM
Pacific Fisher's Avatar
Pacific Fisher
I have used the fumotos on many vehicles. They sure help take the mess out of an oil change. Make sure you order the model with the longer nipple to attach your drain hose. The extra length helps prevent the hose from falling off.
Old Oct 30, 2020 | 05:06 AM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
I won't run one on mine. Too risky to have something kick up and break it off...even if you don't offroad, there's all kinds of stuff on the highway and backroads (semi tire tread, road cones, lumber, tree branches, cardboard boxes, plastic buckets, gas cans, etc...I've hit 'em all in the past)
Subzero68
Aug 22, 2014 12:50 AM
ArtsBest
2009 - 2014 F150
Jun 23, 2011 05:12 AM
navistar2000
6.4L Power Stroke Diesel
Nov 7, 2007 12:40 PM
SuperBlue
Aug 17, 2005 11:01 AM
Max1775
Feb 7, 2005 02:51 PM
