2004 ford expedition horrible noise coming from wheel I believe
Old May 23, 2020 | 06:54 PM
Gears654's Avatar
Gears654
Trailering
So I have a noise that sounds like its coming from my front wheel. It's not a hum it sounds almost like a bike with a card in the spokes. I've looked there's nothing in the wheel. It is 4x4 idk if maybe my actuators are going out. My CV axles spin while driving in 2wd and Idk if they are supposed to be or not. 4x4 does work last I used it. With the noise it's making I don't want to engage it and it not disengage. When it was on a scanner last I remember it had a fault code of some sort in the 4x4 system. There's a slight hum but I know it's not the wheel bearing I was thinking it's my tires but now I'm not to sure. When it stops making the noise it almost sounds like it grabbed like a slipping clutch or something like that.
Old May 24, 2020 | 09:42 AM
alloro's Avatar
alloro
Does the noise change when taking a left or right turn?
Old May 24, 2020 | 10:45 AM
Gears654's Avatar
Gears654
Trailering
No not really but then again I'm not going fast enough in most turns for it to even make the noise
Old May 25, 2020 | 03:25 PM
pdqford's Avatar
pdqford
So, then under what conditions do you hear the noise?
Old May 25, 2020 | 03:27 PM
Gears654's Avatar
Gears654
Trailering
I'm pretty sure it was being caused by a vacuum leak I found and fixed because now it's not doing it but I'm thinking it was actuators trying to activate 4x4 since it was losing vacuum.
Old May 26, 2020 | 10:42 AM
alloro's Avatar
alloro
Yes that sounds like a strong possibility assuming the hubs were only partially engaging due to a vacuum leak. Good find!
Old Jul 16, 2020 | 02:21 PM
Lady Dee's Avatar
Lady Dee
I have the same exact noise and dont know what's going on
Old Jul 17, 2020 | 08:49 AM
alloro's Avatar
alloro
Originally Posted by Lady Dee
I have the same exact noise and don't know what's going on
Did you look for the vacuum leak in the lines going to the hubs?
topdawg82
Jul 3, 2014 10:50 AM
db47
2004 - 2008 F150
Nov 2, 2008 01:01 PM
mike330
Mar 9, 2007 06:36 PM
Expefan
Feb 4, 2007 06:05 PM
orange784x
Sep 19, 2004 10:44 PM
