Next, removing gear shifter.
Old May 3, 2020 | 07:20 PM
MannyC750's Avatar
MannyC750
Cab is almost ready to come off the frame. Need to remove the gear shifter out next. It's been mentioned in an early post that the cap on top of the housing could be pushed down and twisted slightly to release the lever. However, i think my manual drawing shows four bolts holding down the shift lever housing. Not a twist cap. After removing the bolts i think the lever assembly lifts out. Will the spring seat and spring stay in, or come out with the lever?
Old May 3, 2020 | 07:25 PM
EBEAR's Avatar
EBEAR
It doesn't look like that trans has the push down cap . I believe you could take the bolts out but you can also drive the roll pin out that is in the hole that is visible in your pic .
Old May 3, 2020 | 07:43 PM
MannyC750's Avatar
MannyC750
Thank you.
hail destroyer
Oct 20, 2016 11:32 PM
wwgk1980
May 25, 2012 04:44 PM
kingford72
Jul 19, 2011 09:02 PM
DeanBob
Apr 1, 2007 09:13 AM
irocknrol2
1983 - 2012 Ranger & B-Series
Oct 17, 2006 10:20 PM
