Truck feels like its not running on all cylinders after startup..
Old Jan 5, 2020 | 02:00 PM
Jmy11's Avatar
Jmy11
First a little background.. Truck starts right up every time(plugged in or not).. After idling for about 5 minutes or about 2 blocks the engine feels like it is running out of fuel. It starts to miss and buck like its only running on 4 cylinders. After the engine is warmed up it seems to smooth out and is not really noticable.. I have clean new oil and filters. Ihave replaced ipr and icp.(both values seem to be in line with the norms as monitored by scan guage 2) No check engine light or stored codes. i have a regulated return with guage and rock solid fuel pressure at 65psi. Any suggestions would be appreciated
Old Jan 5, 2020 | 04:48 PM
kbeefy's Avatar
kbeefy
Check plugs to UVCH (50 cent mod) and engine harness for chaffing above drivers valve cover
Old Jan 5, 2020 | 04:57 PM
Colorado350's Avatar
Colorado350
Welcome to FTE.
Run the truck then check both manifolds with a IR THERMOMETER and see if there’s a significant difference in temperature...
Old Jan 6, 2020 | 02:02 PM
Jmy11's Avatar
Jmy11
I have ohmed out both plugs at the uvch and also from the 42 pin plug(All injectors ohmed out at 3.4 ohms) Slight chafing on the harness but nothing rubbed through.. I taped and insulated it as a precaution..As far as manifold temps, I checked numerous times at idle and after a "heavy footed" test drive and both manifolds were about the same or within about 10 degrees..
Any other suggestions are greatly appreciated..
Old Jan 12, 2020 | 08:39 AM
Jmy11's Avatar
Jmy11
Is it possible to have plugged screens in the tank and still make 65 psi fuel pressure? Or maybee air intrusion and still make 65 psi??
Old Jan 12, 2020 | 01:01 PM
Wes444's Avatar
Wes444
Air and 65psi yes. Every non H&H truck
You mentioned changing the IPR and ICP, were those both Motorcraft?
Old Jan 12, 2020 | 01:06 PM
Jmy11's Avatar
Jmy11
YES all Motorcraft.. In recent days, I have changed out fuel pump, fuel filter, gone over engine harness and found a bare wire which was the common injector ground for passenger side. This wire was bare but not touching any other conductors or metal. Now I just pulled P0605.. Just reading up on that.. Not sure if that is a result of having batteries and sensors unplugged or pcm problems..
Old Jan 12, 2020 | 03:31 PM
Bonanza35's Avatar
Bonanza35
Sounds like the exhaust butterfly valve is closed till it warms up. You can unplug it to see if that is it.
Old Jan 12, 2020 | 04:37 PM
Jmy11's Avatar
Jmy11
No butterfly, EBPV was deleted and a Banks Power Elbow installed.. i tried running the engine from a fuel can, and the problems are still there so that should eliminate the fuel system. I'm thinking IDM, just haven't got up the courage to buy one yet.$$$
Old Jan 12, 2020 | 05:03 PM
Bonanza35's Avatar
Bonanza35
There's a guy in Tennessee that rebuilds both the IDM and PCM. If you think it's bad, I'd go that route. Sorry I don't have the web info.
Old Jan 13, 2020 | 10:32 AM
Colorado350
‘Here you go: https://www.dieseltechchatt.com/prod...hoCpvkQAvD_BwE
Old Jan 13, 2020 | 12:47 PM
Bonanza35's Avatar
Bonanza35
Thank you John, that should help him!
Old Jan 17, 2020 | 07:12 AM
Jmy11's Avatar
Jmy11
Figured out that it WAS the IDM.. Thanks to everyone that responded and helped with their advice and knowledge..
JHP F250
Aug 31, 2018 09:10 PM
Terrh
Apr 18, 2014 06:04 PM
MadMountainMan
Jun 11, 2013 05:56 AM
Butch(OH)
Jul 30, 2011 10:25 AM
MPlayer
31
Sep 18, 2006 02:16 PM
