Help with numbers....can’t seem to find the right info.
Old Dec 25, 2019 | 06:44 AM
Iron720's Avatar
Iron720
Old Dec 25, 2019 | 07:05 AM
FortyNiner's Avatar
FortyNiner
What are you wanting to know?
Old Dec 25, 2019 | 07:37 AM
Iron720's Avatar
Iron720
Motor size...and wanted to rebuild to keep the truck original ( 54 f350 express ) and the transmission was hacked in...wanted to find proper , we’re they all 3 speeds, as my 53 350 is a 4 speed.
Old Dec 25, 2019 | 07:39 AM
Iron720's Avatar
Iron720
Is it even worth saving....how do you find out if the engine matches the frame etc....
Old Dec 25, 2019 | 07:55 AM
bigwin56f100's Avatar
bigwin56f100
ECG engine block is a 55-57 272 produced at the Dearborn Iron Foundry
the cylinder head numbers didn’t show up in my search. Did they have little disc rotaters on the valve stems at the top? I’ll assume they are sodium filled valves
Edit
the head number looked like EOZ -G but if it’s a sloppy casting I can see where it was a ECZ-G
Old Dec 25, 2019 | 08:08 AM
pintoplumber's Avatar
pintoplumber
ECG is a 272 block. One of your photos shows a ECZ-G head. They are most desirable. I think the date code was 1957 on the head. The y blocks look the same physically, you have a good starting point. Your truck would have come with an EBU or EBV block originally. You could probably turn your 272 into a 292 by boring larger. Should have the block sonic checked first. Before I knew what I was doing I had my 239 y block bored +.125 turning it into a 256 y block. I have since added a crank from a 312 and my 239 y block now measures 283”. Dennis
Old Dec 25, 2019 | 08:27 AM
Iron720's Avatar
Iron720
Wicked thank you guys.
and merry Christmas.
Old Dec 25, 2019 | 10:00 AM
abe's Avatar
abe
Merry Christmas to you too.
You've gotten good advice from two of our many knowledgeable Yblock guys. About the tranny question. Most F350's were four speeds with first gear a granny gear. They could order the optional heavy duty 3 speed with the remote shifter on the column.
lungerbrothers
1961 - 1963 F100 Unibody
Nov 30, 2017 06:17 AM
acapulkomx
Jul 1, 2016 03:07 PM
Mavericksgarage
Jan 31, 2015 10:54 AM
jonesa49f1
15
Jan 29, 2015 08:13 AM
jgoodman6891
Nov 5, 2012 09:45 AM
