Faulty pressure differential valve
Old Nov 9, 2019 | 01:39 PM
itsabullitt's Avatar
itsabullitt
Getting closer to having my 67 f100 running and driving. When I swapped to power disc brakes I also grabbed the pressure differential valve from the donor truck. Now that I'm bleeding the brakes, I find that I have no fluid going to the rear brakes. I've spent the past couple of hours searching on here and decided to just ask for help. I'm assuming the valve is stuck. Is it possible to reset it or am I just going to have to replace it? From my reading on here, the factory valves are no longer available. So that leaves me with aftermarket. If I have to replace it, what do you recommend replacing it with?
Thank you as always for the help.
Old Nov 9, 2019 | 03:28 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
What year and series was the donor truck?
Old Nov 9, 2019 | 03:45 PM
itsabullitt
Sorry, that would have been helpful. Was a 77 2wd F150.
Old Nov 9, 2019 | 05:01 PM
resonateur's Avatar
resonateur
Try to take it apart and clean out the old brake fluid and residue. The repro’s have a high tendency to leak.
Old Nov 9, 2019 | 05:24 PM
NumberDummy
Sorry, that would have been helpful. 1977 F150 2WD
D5TZ-2B257-B .. Brake Pressure Differential Valve / Marked: D5TA-2B524-FA or FB / Obsolete
1975/79 F100/150 2WD/4WD // 1975/79 F250 2WD with 6200 lbs. GVWR with single piston caliper disc brakes // 1975/79 E100/150 // 1976/79 Bronco // 1976/79 F250 4WD // 1979 F350 4WD
Old Nov 11, 2019 | 09:33 PM
1TonBasecamp's Avatar
1TonBasecamp
The shuttle **** does not shut off fluid flow though, so even if it was tripped off-center you would still have pressure to the rear brakes. So the blockage is either gunk related as suggested, or somewhere else.
Makes sense that it's the valve of course, since you did not have this problem (presumably) before. Unless you did and didn't notice it until now? Happens sometimes...
So being a '77 then this is a "combination valve", correct? Isn't the "pressure differential valve" just the old "H-block" style with the switch for the dash light only?
Would not a '77 have had the full complement of functions, including the delay valve (hold-off valve) and proportioning valve for the rear?
I don't think there is a way to plumb it backwards, but if there is could the hold-off valve be in the rear brake circuit and not opening up?
Actually, when they work and are the type used on lighter duty trucks (light 250's and supposedly all 150's) you can actually see the little nipple thingy move out as you push on the brakes. It's the bit you're supposed to pull out manually as you're bleeding the front and normally has zero effect on the rear brakes.
Which is why I was wondering if it is possible to plumb it backwards. The hold-off valve is known for sticking closed and blocking fluid to the front.
What else was changed? And what else was not changed?
Is the master cylinder new, or from the donor? Are the front brakes plumbed to the rear port and the rear brakes to the front port?
Good luck. Very curious what you find.
Paul
Old Nov 11, 2019 | 10:36 PM
itsabullitt
Thank you for the replies. Brake lines and master cylinder are new. The lines are plumbed correctly as the larger rear pot of the master cylinder is going to the front calipers and I am getting fluid there. When pulling the line from the pressure differential or combo valve to the rear brakes, no fluid comes out of the valve. The only part not new is this valve, which was sitting exposed, so I'm positive it's either just clogged with junk or is just ruined. Plan is to pull it apart and see if it's able to be cleaned or repaired. If not, then try to find another used one. Thanks numberdummy for the vehicles to look out for.
Old Nov 12, 2019 | 11:24 AM
1TonBasecamp
Let us know what you find.
And I think it was someone here recently that had a bad "new" master cylinder that only pumped out of one port. Might have been over on classicbroncos, but not sure.
Seems like we run into problems with new parts all over the place these days. Does not have to be electrical anymore either. I even had a customer that after all the tests found that something was clogging his brand new combination valve I'd sold him!
Up to that point the only problem had been leaking hold-off valves. Which to me was enough of a problem to stop selling them. But we'd kept up because not everyone wanted the alternative that I personally think is the way to go, and that's the manually adjustable rear proportioning valve.
After his experience though, I at least know to suggest it if someone has an odd issue that defies explanation.
Good luck.
Paul
Old Nov 23, 2019 | 04:26 PM
itsabullitt
Was a bad valve. Replaced it with Speedway part number 910-31364. Bolted right in to factory spot on the engine cross member. Only one port was the wrong thread size, but an adaptor from O'Reilly fixed me right up.
Old Nov 23, 2019 | 08:20 PM
1TonBasecamp
Nice! Glad you got it working right again. And good to know the part number and how it fits. Thanks for keeping us updated.
Any idea what was wrong with the old one? Gunked up I'm guessing, or something else going on?
Paul
Old Nov 23, 2019 | 09:40 PM
itsabullitt
Paul
I honestly didn't take the old one all the way apart, but the piston/plunger was stuck in place. Ordered the one from Speedway not knowing how close it would be and was super excited to see the mounting bolts and all the ports were in the factory locations.
Old Nov 23, 2019 | 11:56 PM
1TonBasecamp
Did you get the full kit with the mounting bracket? Sounds like you didn't use it and just put it back where it was.
That's fine too (and less plumbing trouble) but if you are ever plumbing a whole new system, or if you ever get an adjustable one for whatever reason, mounting it up on the master is the way to go.
Paul
Old Nov 24, 2019 | 07:19 AM
itsabullitt
No, just used the factory bracket since we already had all new brake lines ran to the factory combo valve.
Sidekick41
Jun 8, 2017 09:45 AM
coachgracey
Jan 19, 2015 08:41 PM
78workhorse
Aug 28, 2011 06:35 PM
dynamic
May 10, 2010 06:49 PM
7702fordboy
Dec 30, 2005 08:12 AM
