1953-56 (and others) F100 Frame Rust Problem Areas
Old Nov 5, 2019 | 03:49 PM
eff_it's Avatar
eff_it
Hi FTE,
I've been looking around for a few days and I really haven't nailed down what to look for in terms of frame rust hotpots/problem areas when it comes to buying a "project". I'd really like to compile a list of frame rust problem areas that would necessitate a "hard pass" and just frame areas to look for rust.
Any help greatly appreciated!
Old Nov 6, 2019 | 09:36 AM
bhalemail's Avatar
bhalemail
To be honest with you i haven't seen much in the way of rot on these old frames unless they are sitting in a filed sunk to their axles/frame.
On my 53 you could still read the part numbers on the frame cross members but when i stripped it down the only rust evidence that i saw was a little pitting on the upper part of the frame that the bed sits on. Likely due to rotting wood floor and collection of junk in that area. I could see where there could be issues with the areas where the cross members join with the main frame rails if mud and junk got in there but i didn't have any thankfully. You can or should be able to easily look under the truck at all sections of the frame and get a good idea of what's there. The sheet metal is another story but obviously areas are cab floor, cab corners(front and rear), lower fenders/etc but most of that is to be expected to some degree. You definitely want a solid frame to start with.
Old Nov 6, 2019 | 12:12 PM
bjmayberry2's Avatar
bjmayberry2
Veteran: National Guard
As stated by bhalemail these frames aren’t prone to rust through. You will find pitting in a couple of places that tend to hold water or trap dirt. Frame issues are usually with things mounted to the frame i.e. front cab mounts (cracks) and spring and shock mounts, frequently welded due to rivets breaking.
Again as stated earlier the bodies are a totally different story.
Old Nov 6, 2019 | 12:27 PM
raytasch's Avatar
raytasch
Believe Nothing
I once saw a 1954 F100 that had frame rust thru at the vertical member in the area of the front rear spring hangers at the rear of the truck. A plate on both sides of the frame inside vertical surface had been the repair.
Old Nov 6, 2019 | 04:59 PM
bhalemail's Avatar
bhalemail
Yes! I should've added that one of my front frame cab mounts was cracked and needed welded. I wouldn't have seen it had i not taken the cab off and blasted it. The steel was in excellent shape so the repair was simple
Old Nov 6, 2019 | 06:26 PM
56panelford's Avatar
56panelford
I've also seen quite a few frames with cracks at the steering box..
Old Nov 6, 2019 | 08:45 PM
CharlieLed's Avatar
CharlieLed
On the list of things to check on a project truck, frame rot would be pretty far down on the list especially in CA. As others have said, cracks and poor workmanship by previous owners is a more likely issue. I had a 54 some time ago that I bought as a basket case, the PO put a built 390 in it and virtually trashed the frame because of the way it was installed.
Old Nov 12, 2019 | 03:06 PM
eff_it's Avatar
eff_it
Thanks guys, this is very helpful!
coldsteel187
Sep 4, 2010 06:52 AM
griz4718
1983 - 2012 Ranger & B-Series
Nov 10, 2006 09:12 AM
shelby987
Jun 25, 2006 10:28 AM
1982fordf100
Nov 17, 2004 12:33 AM
