2003 F350 A/C blowing hot?
Old Sep 3, 2019 | 07:43 PM
Lockholder's Avatar
Lockholder
I replaced my ac compressor and used the Freon in a can and the truck still blows hot air. I had a shop drain the old freon out first
Old Sep 3, 2019 | 08:02 PM
Walleye Hunter's Avatar
Walleye Hunter
Did you pull a vacuum down and check for leaks before installing fresh Freon?
Old Sep 3, 2019 | 08:20 PM
BWST's Avatar
BWST
Got Data?
I had to do this when my condenser failed on the Tahoe. If you've added refrigerant, and it still blows hot, I wonder if there might be a leak in the system.
Tell us how you recharged the system. How many lbs of R134a have you put in. Did it take the full amount listed on the sticker under the hood?
Below is a link to a procedure similar to the one I used on the Tahoe. I purchased a vacuum pump and manifold gauge set from HF with good results. It's been a year and the rig is still blowing cold.
https://www.2carpros.com/articles/re...itioner-system
Old Sep 4, 2019 | 11:00 AM
'88 E-350's Avatar
'88 E-350
Unless you evacuated the system after installing the compressor it has air and humidity in it. If the old compressor pumped any bits out you could have a clog in the system. You didn't state how much refrigerant you added, or what the pressures are or, even if the compressor is engaging so who knows. If you used only one can you are far from full.
tidexp
24
Jul 8, 2012 08:23 AM
Nevada Max
Jul 22, 2006 02:45 PM
DOUG5G
Aerostar
Jan 29, 2006 06:47 AM
HENDEL JR
Jul 5, 2005 03:51 AM
Bob O GomA
1983 - 2012 Ranger & B-Series
Sep 23, 2004 07:44 AM
