6 inch radius arm drop bracket frame twist
Old Aug 9, 2019 | 12:47 PM
OVRLNDR's Avatar
OVRLNDR
Hi, I noticed my RC 6 inch radius arm drop brackets are bending inwards \ / which is twisting the frame so the lower fender is being pushed out 1/2 inch from the doors.
A common problem?
Is there a fix for it or a way to stiffen them up?
TIA
Old Aug 9, 2019 | 08:11 PM
moose4x4's Avatar
moose4x4
FTE Emeritus
Make a brace to go from one bracket across to the other. Make sure you get them straight before attaching.
Old Aug 9, 2019 | 08:53 PM
Franklin2's Avatar
Franklin2
What is the front cab mount doing? It's in the same area as the mount for the radius arm.
Old Aug 9, 2019 | 11:43 PM
Rogue_Wulff's Avatar
Rogue_Wulff
Solid axle swap. TTB is worthless with lift kits.
