'55 divider bar to anti rattle insert config?
Buttoning up for the wintah.
Im putting the divider bar in LAST (before side glass and regulator) but:
Maybe Im a bit out of install order with this. I got one door window prepped to push in the glass, but I have no picture (and of course I was not smart enough to take one)of the horiz anti rattles right at elbow level.
Do the ends at the divider bar fit outboard of the divider bar window channel or inside it? (or are they trimmed to butt up?)
At the other end of the anti rattles. do those curved tails go outboard or inboard of the rear side of the window channel?
I would assume if they go outboard, then prying the antirattles out and praying the clips dont fail is the only way??
Cruiser
My stuff is aftermarket. Right at the divider bars, my fuzzies pretty much end. At the rear, the fuzzies go on the outside of the anti-rattle. I hope you have better luck than I and a few other here did. They are miserable to install without tearing out the rear most clips. If you learn anything, please don't forget to share it.
Jim
That's the part that can hang you up. I have bought a couple sets of the horizontal fuzzies. The rearmost clip always seems too close the the next clip. How did you move the clip in the backing of the fuzzy, without it pulling out easily during install? I'm going to try the grease tip next time.
I had the anti-rattles in before the division bar. Also bought the D Carpenter pieces. I remember no problems with that rear most clip ( WHere it 'hockey sticks" up) , but its clear they are 1/8 to 3/16 longer than where I want my division bar to land.
I have worked the ARs outside of the division bar channel with sets of taped up flathead screwdrivers (an attempt to keep from crunching the paint job
) , but it appears I only managed to separate the SS part and put that outboard, leaving the fuzz and metal fuzz backing inboard and too snug overall to run glass up the division bar channel. Rather than risk chipping paint and ruining the ARs altogether, Im thinking of a) removing the vent assys (4th time), b) marking the ARs where they shoud be trimmed to butt up to the DB, c) takeing out DB top screws and taping it to hold it fwd. d) shimming out the AR away from the paint, then trimming with a Dremel bit. Comments?
That's your best shot IMO. None of the ARs and fuzzies appear to be designed to be removed and then re-used. They are just too delicate. There are lots of tears on my garage floor from this phase of the operation. I'm afraid it's one of those things that requires experience. And the education is expensive in terms of destroyed parts. I have DC as well as lesser brand parts. Your windows are very likely going to be too tight until they wear in over time. There just isn't enough room in there for everything. I suppose it is so they will continue to seal after the break-in period. I'm afraid my power window motors are going to suffer reduced service life because of the close fit.
Jim-since the rear of the ARs are sitting pretty, I'm going to try to prune the front to butt up to the DB.
I'll provide feedback to close the thread, however it will be quite a few weeks later b4 I can get back to the task.
I'll also take a stab at what order of assy may provide the best result, since that could be the key to window rebuild Nirvana
