New* 1977 F150
Old May 13, 2019 | 06:46 PM
pollila1's Avatar
pollila1
New* 1977 F150
This bad thing is on its way down to me from Washington! Just another day or 2...Cant wait......I'll post more pics when its here
Old May 13, 2019 | 08:53 PM
gohunt's Avatar
gohunt
Very Nice!
Old May 13, 2019 | 11:08 PM
desperado_18_2000's Avatar
desperado_18_2000
Very nice! Hopefully it drives and runs as nice as it looks!
Old May 13, 2019 | 11:31 PM
Enzothehound's Avatar
Enzothehound
Great looking ride!
Old May 13, 2019 | 11:50 PM
Ptjsk's Avatar
Ptjsk
Wow! Sure looks good from that one pic! Tell us about it.
Pat
Old May 14, 2019 | 10:57 AM
njdevil77's Avatar
njdevil77
Very nice indeed!! Can't wait to see more and please details details details!!!!
Old May 15, 2019 | 12:39 AM
pollila1's Avatar
pollila1
details, details, details:
-Headboard, tailgate, side panels, all brand new from LMC truck parts. Color match ring line. Wood floor bed in great shape.
-Rancho 4 inch lift, tuned adjusted.
Mad dog custom headers, 3 inch exhaust.
Also slotted front disc brakes.
-390 bored 30 over, balanced, trw pistons,comp cam282, rare edlebrock fe port match to medium 427 heads. All msd ignition, Holley 780. Aluminum water pump, everything new under the hood
-Ladder bars, 9 inch ford trac lock. Everything from to drum is new.
-Driveline is all new.
-Transmission, 64 galaxie Borg Warner close ratio 4 speed with Hurst shifter.
Transfer case, 74 bronco; HD; was behind a 351 w with bronco shifter.
All rebuilt.
-Interior all new. Custom seat, new foam.
New switches and gauges. LMC or napa parts. Pioneer deck, kenwood amp ect.
-High volume oil pump. All oil journals where drilled and opened up larger for more flow. Example from the oil pump to the filter, 5/16 hole is now 3/8 in size.
-390fe cid
427 top end
Trw pistons
Comp cam
MSD
780 holley, ect.
450+ hp
4 inch lift
Rancho 9000
Hurst 4 speed
9 inch traclok rear differential
High pinion front differential
New interior
About 130,000 on the chassis 2,000 on the restoration
Old May 15, 2019 | 12:50 AM
pollila1's Avatar
pollila1
Special features
High-perfonnance 420 cu-in
. V-8 engine, four-speed manual transmission, limited-slip rear differential, four-wheel drive, power front disc/rear drum brakes. power steering, aftermarket CD sound system.
Comments
Engine/lEngine Compartment
The eng
ine compartment was clean and well maintained. Owner said the engine has been completely rebuilt, including a balanced rotating assembly, upgraded with an increased-displacement crankshaft, a performance camshaft, high-compression cylinder heads, a high-flow intake manifold, four-barrel carburetor, a high-torque starter, electronic ignition, and custom tubular exhaust manifolds. The engine was equipped with a number of dress-up items including cast-aluminum valve covers, spark-plug wire looms, and chrome air-filter housing. An electric cooling fan had also been installed. All engine- compartment surfaces were painted. Belts and hoses appeared in very good condition, and wiring was properly routed and secured. There were no visible fluid leaks.
Chassis
The frame and suspension appeared in very good condition with no significant fluid leaks from the transmission, transfer case, or front and rear differentials. The custom
-fitted, aluminized dual exhaust system was also in very good condition. The system comprised 3-in. exhaust tubing from the exhaust manifold to the mufflers, and 2 Y:z-intubing for the tailpipes, which had chrome tips. Wheels were aftennarket NASCAR-style powder-coated steet equipped with chrome center caps and lug nuts and all were in excellent condition. Tires were 35X12.50X15L T radials which showed excellent tread, with no unusual or irregular wear patterns. Owner said the transmission, transfer case, and front and rear differentials had all been completely rebuilt, and the clutch had been replaced. The transfer case is a 1975 Ford Bronco unit and the rear differential is a Ford 9-in unit with traction control.
All suspension components, including shocks and suspension bushings were new, as were all brake system components. The rear suspension has been upgraded with traction bars to eliminate rear axle tramp.
Interior
The inter
ior was all new and in excellent condition. The seat is upholstered in a custom vinyl and cloth combination and the door panels, headliner, and padded dash are aftermarket original-style pieces. New cut-pile carpet was also installed, and owner said the cab interior received extensive sound proofing. The dash was equipped with a fun set of gauges incruding speedometer, tachometer, water temperature, oil pressure, and fuel gauge. The steering column was fitted with an aftermarket leather wrapped steering wheel with poltsned-aluminurn spokes. All interior metal surfaces were freshly painted. A new AMIFM/CDsound system was installed. All interior handles and ***** were in very good condition, as were the transmission floor shift and front-wheel-drive control.
Exterior
The exterior of the truck had been newly refinished in base-coat/clear-coat paint in the original co
llor, and the paint showed excellent gloss and reflectivity. The finish appeared to have been applied over ~I well- prepared surface, and fit of the doors, tailgate and hood was very good. The bed's front panel, side panels, and tailgate were all new. The front bumper was in excellent condition, and all trim, bezels, and emblems appeared original and were in goOd condition. The grille was original and in good condition, showing only a few minor dings in the grille surround. All glass was original with the exception of the windshield, and was in very good condition. The bed floor was fitted with new oak flooring and attachment strips painted body-color. The bed side interior was coated with a coror-coordinated Rhino liner material.
Summary Comments
This particular vehic
le is a popular Ford pickup body style that is most aptly described as a "restmod," meaning that it has been comprehensively restored and mildly mOdified, with upgrades in the cnassls and drive train, offering much-lmproved performance and handling and enhancing its desirability and value, while still appearing as mostly stock, It's a truck that was built to be driven and enjoyed on the road or on the show field.
Condition Grade: #3
Description of #3 Condition:
Very Good - Completely operable original or older restoration showing wear. Also, a good amateur
restoration, aI/ presentable and serviceable inside and out. Plus, combinations of well-done restoration and good operable components; or a partially restored car with all parts necessary to complete it, and/or valuable NOS parts. This is a 20-footer. That is, from 20 feet away, it may look pertea. But as we approach it, we begin to notice that the paint may be getting a little thin in spots from frequent washing and polishing. Looking inside, we might detect some wear on the driver's seat, foot pedals, and carpeting. The chrome trim, while still quite presentable, may have lost the sharp mirror-like reflective quality it had when new. All systems and equipment on the car are in good operating order. In general most of the vehicles seen at car shows are no. 3 vehicles. (Source: Old Cars Price Guide)
Old May 15, 2019 | 06:50 AM
Meridian_Mike's Avatar
Meridian_Mike
WOW..... looks great..... Lots of bells and whistles.....
Congrats on it finding you!
Old May 15, 2019 | 07:41 AM
njdevil77's Avatar
njdevil77
Nice find, good looking truck! Congrats
Old May 15, 2019 | 11:42 AM
meangreen92's Avatar
meangreen92
Now that's a nice truck!
Old May 17, 2019 | 08:53 AM
Ptjsk's Avatar
Ptjsk
Thanks for the details. That is one nice....nice, truck!
Pat
SteveBricks
Ride Of The Week
Feb 9, 2021 01:26 AM
Redrkt
Wyoming Chapter
Sep 2, 2014 05:03 PM
2002sport
2004 - 2008 F150
May 5, 2010 07:56 PM
dzldude
Jan 2, 2008 06:49 PM
tyrbos
Oct 4, 2007 11:55 AM
