1956 F600 front brake adjuster direction help
Old May 5, 2019 | 06:57 PM
OldStyle's Avatar
OldStyle
Rusty Roller
I have a passenger side front adjuster that is frozen on my F600. Need help to know which direction to turn it to loosen. Drum is stuck so it's either figure it out or cut the adjuster. Heat, aerokriol nor pounding has been successful at this point.
Are both sides right hand threads or are they different side to side? Are the adjusters the same as 49-63 or were the heavier trucks different?
Thank for any help!
Old May 6, 2019 | 03:13 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Thank for any help!
Upper pic, type the basic part numbers of the parts you need. JH = P500 Parcel Delivery, T = F500, TH = F600, W/WH = C500/600 Cab Forward, Q = F750.
The parts you need may not fit all these trucks.
Old May 6, 2019 | 08:39 PM
OldStyle's Avatar
OldStyle
Rusty Roller
Thanks Bill! I'll be needing new wheel cylinders. Finding the correct, upper pic, ones will be the next hurdle... Thanks to everyone who took the time to read my post too. With some more skin and bruising I got it to free up. Second to last strike produced a sore finger tip from a sideways blow. Ain't that always the way! Well worth freeing the adjuster and removing the hub!!!
Both sides were right hand threads. These F600 adjusters are much larger than F100/250 as can bee seen in the pics below. Cleaned up and anti seized the originals are now good for many more miles of service!
Passenger side
The devil you say
Much bigger
Leverage
Well worth it!
Been a work horse for me going on 15 years! New shoes down at the tire shop!
Many thanks to this forum! Glenn
1950 F3 Step-N-Serve
43
Oct 11, 2021 11:01 AM
tjeick
May 24, 2019 05:33 PM
GJPilcher
110
Feb 19, 2018 06:27 AM
ice cream truck guy
Mar 25, 2010 03:38 AM
Ford101
18
Sep 14, 2008 06:19 PM
