Crank shaft backlash
Old May 3, 2019 | 06:55 PM
Hotrod350's Avatar
Hotrod350
Today I was reading several posts trying to figure out why my engine is unreliable. One page I stumbled into mentioned timing chain issues and that one way to check was to turn the crank back and forth by hand and see how much it moved before the vavle train started to move.
I put the engine at the dampers TDC marked and watched the roator on the distributer for movement. There appears to be 7 degrees of backlash between my crank and distributer. Now since there will be a bit of backlash between the cam and distributer gear I took the vavle cover off and checked the rocker arms. Same result.
Is this a normal amount of backlash or an I going to be pulling the front end off of my engine ... Again?
Old May 3, 2019 | 07:12 PM
CharlieLed's Avatar
CharlieLed
Interesting troubleshooting technique for what seems to be a broad malady..."unreliable".
As for checking valve train movement, I am not sure that the distributor is a good indicator of "valve train movement". I think that if you looked at the actual valve train, ie. pushrods, rockers, etc. you may find that your 7 degree measurement may drop. How do you define "unreliable"? I have never personally used this technique or have ever related slop in the timing chain/gears to an unreliable condition. I hope you find some concrete resolution to what you are seeing.
Old May 3, 2019 | 08:30 PM
1960fordf350's Avatar
1960fordf350
You didn't mention why it is unreliable. What does it do? The only purpose I know of to check rotating that back and forth is if your checking your cam to make sure it's degreed in correctly. I don't know how sloppy a chain can be, but, 7 degress isn't much play as far as I'm concerned. And if the distributor is sloppy you're getting even a worse reading. You need to give us the basics of the problem
Old May 3, 2019 | 08:31 PM
ALBUQ F-1's Avatar
ALBUQ F-1
When timing chains wear, it retards the cam timing and also the ignition. The ignition timing can be compensated for by resetting it, cam timing can't. But I agree, it wouldn't make your engine unreliable, just not as peppy at low speeds. Might also make some noise if it's really worn. What engine are we talking about?
I have heard stories about aftermarket chains being garbage, but mostly in the context of OHC engines with long chains. Otherwise they should last 100k miles at least.
Old May 3, 2019 | 09:56 PM
Hotrod350's Avatar
Hotrod350
Your right "unreliable" is a bad way to describe my problems. My engine is a 223 I6, there is no exhaust on the manifold yet. I can get the engine to idle fine but when I try to rev the engine it stumbles and tries to stall out. I can get it to rev higher but I have to slowly apply the gas to do that. After a period of "high" RPM's, when I let off the gas the manifold shoots flame. I say "high" because I can't go WOT without the engine trying to stall out. I will try and get a video of the engine running tomorrow and see if that helps.
Old May 3, 2019 | 10:52 PM
seaves46's Avatar
seaves46
That sounds more like a carb issue than anything else .
With the air cleaner off and engine not running , can you see fuel squirt into the carb when you pump the pedal ?
Old May 3, 2019 | 11:04 PM
mOROTBREATH's Avatar
mOROTBREATH
Is the carb rebuilt? What kind of distributor does it have, the original Load-O-matic? Is the vacuum line hooked to the carb? What is your distributor timing set at?
Old May 4, 2019 | 08:17 AM
52 Merc's Avatar
52 Merc
You need an exhaust manifold on it. Having an oxygen source that close to the combustion chamber will mess with your tuning, and it's really hard on the exhaust valves to be exposed to cold air like that. You can warp them.
Mikerage
1997 - 2003 F150
30
Jul 29, 2016 02:59 PM
copyman
Jun 20, 2014 06:32 PM
robjs111
1978 - 1996 Big Bronco
Mar 7, 2013 11:02 PM
fordberg
Jul 30, 2007 07:01 AM
qman
Jul 28, 2005 12:42 PM
