tire pressure monitor
Old May 3, 2019 | 05:54 PM
jerdawg's Avatar
jerdawg
hello , just trying to find out how to reset the tpm on a 2019 f350 limited , i lowered the pressure to get a better ride but the dealer says they cannot reconfigure to shut the light off and maintain the system to continue to work , just looking for some ideas
Old May 3, 2019 | 06:18 PM
Tricon's Avatar
Tricon
Use FORscan to set what ever pressure ranges you want. Search the forums for FORscan and you'll find the thread on it.
Old May 4, 2019 | 06:12 AM
RGPolo's Avatar
RGPolo
How low did u go? I'm down to 55/56, no light.
Old May 4, 2019 | 07:06 AM
jerdawg's Avatar
jerdawg
currently have them set to 50 frt and 55 rear , but i also tried them at 55 / 60 and the light was on
Old May 4, 2019 | 07:11 AM
Section179's Avatar
Section179
There could be an f350/250 factor here. On my 350 rear tires light up below 60lbs.
Old May 4, 2019 | 07:41 AM
RGPolo's Avatar
RGPolo
Yea, maybe, I have a '19 F250. Makes sense with F350 extra payload capacity.
Old May 4, 2019 | 11:19 AM
Hjabernathy's Avatar
Hjabernathy
I have a 2019 F350 with the heavy duty front suspension (due to choosing the Electronic Locking Differential) with the 5990lb front springs. My door jamb sticker says 80psi rear and 60psi front. I describe this information simply for reference purposes. Shortly after getting the truck in December 2018, I tested the TPMS system to see where the light came on. It illuminated at -35% on both the front and rear, 52psi on the rear and 39psi on the fronts. I posted this information on this forum and was surprised to have more than one person reply that their low-pressure light came on at much higher pressures in the same model Super Duty Ford Truck. It is unfathomable that the factory settings of the TPMS system would react differently on trucks of the same size.
Unfortunately I can’t answer the OP’s question as to how to reset the TPMS triggering pressures. I would find it very user unfriendly if the only way to change the triggering pressures is by using Forescan. I haven’t lowered and raised my tire pressures with this truck for two reasons: I am a full time RVer pulling a moderately heavy travel trailer most of the time, and the truck bed is always nearly fully loaded. As such, it rides very well with the recommended inflation pressures of 80 rear and 60 front. However, I may want to change pressures in the future. I did purchase a TPMS Triggering Tool in case I needed to reset the wheels after rotating them if I did my own rotation. I haven’t used it yet. I’m wondering if using that tool resets the TPMS triggering pressures also since the process does involve the truck’s computer(s).
Old May 4, 2019 | 11:33 AM
jbrnigan's Avatar
jbrnigan
^^^^^^^^^^^, mine are set at 50 psi, frt and rear, adjusted with FORscan....no lights
Old May 4, 2019 | 11:39 AM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Yup. Do what Tricon said. I've kept my tire pressures at 60F/50R since I picked it up new and have just been ignoring the light on the dash for 8 months. Well today, I had to get out Forscan anyways, so I finally changed the threshold to 55psi on the rear. After a 1/2 mile drive, the light is off and no warning on start-up.
I don't know why I didn't do it sooner!
Boxer19
2014+ Transit
Aug 8, 2017 10:14 AM
bushpilot
May 10, 2017 10:06 AM
ysgi
Jan 5, 2017 09:56 AM
whiteywhip
6.7L Power Stroke Diesel
17
Jan 17, 2013 09:50 AM
