Lengthening drive shaft
Old Feb 26, 2019 | 06:54 PM
Rowdy73's Avatar
Rowdy73
I'm to the point on my build where I need to lengthen the drive shaft but I need help with how much longer to make it. The pic is with it bottomed out in the slip yoke. I only have a few inches of suspension travel so it wont be sliding in the slip yoke too much. I'm thinking about 2 and a half inches longer but I wanted some other opinions before I take it to the drive shaft shop
Old Feb 26, 2019 | 09:08 PM
dman2008's Avatar
dman2008
From what I understand they won't "lengthen" a driveshaft, you get to buy a new none. Been there done that.
D
Old Feb 26, 2019 | 09:13 PM
Rowdy73's Avatar
Rowdy73
I've talked with the shop in town and they say they can do it no problem it's just a matter of the correct measurements
Old Feb 26, 2019 | 09:35 PM
ford390gashog's Avatar
ford390gashog
Well what's your slip yoke length? You want to go 2/3 of the slip yoke in and then measure. To lengthen a driveshaft is just a matter of removing the old tube and install a new longer tube.
Old Feb 26, 2019 | 10:10 PM
Rowdy73's Avatar
Rowdy73
I haven't taken that measurement but I'll have to do that tomorrow. The first probably 2 inches of the slip yoke are smooth too before the splines start
Old Feb 26, 2019 | 10:15 PM
ford390gashog
Shouldn't be, what driveshaft and transmission are you using?
Old Feb 26, 2019 | 10:24 PM
F100 '64's Avatar
F100 '64
Hey Rowdy, I went to a well known at least in my part of the world, one man shop who has been doing driveshafts for 30+ years. He told me that due to the way Ford makes the CV driveshafts the yolks cannot be reused to lengthen the DS and he'll need to make a complete new one.
As I recall driveshafts are measured center point to center point at the universal joints. So I installed the CV DS into the trans and measured the distance from the differential flange to the rear flange on the DS. We did this with the rear suspension loaded. I then added that to the length of the CV driveshaft.
My truck is a long bed and the DS came in at 70 1/2 inches. Some say that's on the long side. My guy said at my horse power (225 HP) and using a 3 1/2 inch diameter tube I should be fine. Out the door it was $300.00.
I'm pretty sure I'm remembering all of this correctly, you may want to Google to confirm. Best of luck, Pat
sperober1
1997 - 2003 F150
Jul 1, 2014 06:47 PM
Trudi Gill
Escape & Escape Hybrid
Jan 30, 2013 08:51 AM
SuperDuty93
16
Dec 21, 2011 06:55 PM
jav409
Jun 2, 2008 08:24 PM
tangcoral2004
Jun 30, 2005 12:39 AM
