Was having a really low duty cycle while driving, I opened up the holes on my stock IPR but didn’t totally cure the problem. Had a friend machine out an aluminum block to fit two IPR’s to make better flow. I believe the stock edge filter make have restricted the flow some.
Did it help? I tried a honey badger a while back. Same issues. Low duty cycle, no power. Put a real pump in and it was back to good power and duty cycle back up.
The honey badger jr I got has done fine for me. For now. I’ll keep using it till it quits.
Just a little more detail, when I had both pumps on and got above 1500 rpm, the duty would settled down when you weren’t calling for anymore throttle, it went all the way down to 3.1%. That threw the CEL. Never could figure out why when I first started using the truck.
