Torque converter disengaging and seems to get hung in 4wd
Old Dec 16, 2018 | 03:47 PM
95 F250 7.3 4x4 AUTO's Avatar
So my torque converter is disengaging and then reverse didn't work. I put in 4wd and reverse works. But when I put it back in 2wd it sounds like it's getting hung in between. I put on a vss but the torque converter still disengaged. I bought the vss connector but haven't put it on yet. I checked fuses and besides a couple looking old and dirty, I didn't see any that we're bad or disconnected. I recently had a similar problem and it was a fuse. Could a fuse not be disconnected or broke but still be bad? Any idea would be great since I don't have money to take it to a mechanic. You guys have been great in the past so I have a lot of confidence in this site and all you Saints that have helped me keep Big Blue going. Thank you in advance.
Old Dec 16, 2018 | 08:51 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
What do you mean by the torque converter disengaging? Describe what it's doing.
Old Dec 17, 2018 | 09:45 PM
When I let off the throttle it seems to spin freely
Old Dec 18, 2018 | 07:45 AM
Mark Kovalsky
It's supposed to release the torque converter lockup clutch when you let off the throttle.
Old Dec 18, 2018 | 09:22 AM
I must not be doing a good job of describing what's going on. I will change the vss connector, change the #13 fuse and then maybe make a video so I can better describe it.
Old Dec 18, 2018 | 09:44 AM
knottyrope's Avatar
knottyrope
working in x4 and not 2wd, maybe something is not driving the rear drive shaft but will drive the front
Old Dec 21, 2018 | 04:12 PM
I don't know what to do. Reverse is working in 4wd but when I put in 2wd it grinds when in reverse and park. It does go into drive though. No overdrive light or any other lights are coming on. I'm just not sure what to do at this point.
Old Dec 21, 2018 | 09:25 PM
Mark Kovalsky
I suspect a problem in the transfer case.
Old Dec 22, 2018 | 11:24 AM
I've been told to start with the transfer case linkage. I don't know how to do that but I'm going to see if I can find a video on YouTube. If Mark and the service advisor at Ford think it's the transfer case then I would imagine they are right.
Old Dec 22, 2018 | 11:35 AM
Hit Man X's Avatar
Hit Man X
Thumbs up
There is an aluminum pivot lever that hooks the shifter in the cab to the t-case, pretty common for them to crack. Bud dealt with this, cannot really explain it further. Driver side, by the manual linkage of the E4OD.
Old Dec 22, 2018 | 11:41 AM
Hit Man X's Avatar
Hit Man X
Thumbs up
This guy! It very well could be your issue.
Old Dec 22, 2018 | 01:48 PM
Thank you. I will check that out now.
Is this the "filler plug"? As I was putting on the VSS connector I noticed it was almost falling off. I tightened it down then finished the connector. I then pulled the truck forward about ten feet and noticed I had anti freeze leaking. That's new. Is it related or a separate issue?
Old Dec 22, 2018 | 03:57 PM
Hit Man X's Avatar
Hit Man X
Yes. That is the rear axle fill plug. 75W140 or 85W140 is what you want in there...did the anti freeze come from there???
Old Dec 22, 2018 | 04:51 PM
No the antifreeze did not come from there. Why would it be loosened all the way to the last thread? And could that cause me problems?
Old Dec 22, 2018 | 05:40 PM
Hit Man X's Avatar
Hit Man X
Maybe the PO did not tighten the plug correctly. Is that your adapter on there too? Yes, a loose fill plug can cause issues...you could run dangerously low on gear oil. Parts can overheat among other issues.
Coolant loss is not fun. Probably radiator or water pump. Either way, may as well flush it all out and go with some Fleetcharge coolant that has SCAs in it. Consider a filter too.
