What did I screw up???
Old Dec 15, 2018 | 06:59 PM
MD_7.three's Avatar
MD_7.three
changed out my glow plugs today and just a run of the mill oil change but did switch to T6 5w-40 syn and all the truck has ever known is 15w-40 dino. Also new GP relay, all new uvch’s, and torqued down the injector hold downs to 120 in-lb and rockers to 20 ft-lb.
everything went really well...I had a buddy helping and from start to finish had it all done in just a hair over 4 hours with a few beers and a sandwich along the way...fired right up, drove great home about 15 miles from his garage...it was raining so I didn’t really stomp on it but all the numbers I monitor in forscan looked good...
Tonight I ran out to pick up dinner and decided to hit it WOT on the empty “highway” ... you know....just wanted to make sure I tightened all the cac boots good enough and didn’t have a boost leak...everything was good/normal, then right around 60/65 with boost at about 15psi I had a sudden loss of power...dash lit up like a Christmas tree...SES, water in fuel, hell I think even the WTS light flashed...it did not die, just seriously defueled but only for about 1-2seconds and then as my foot came off the go pedal it was back to normal, I did a little wtf freak out and then gave it some gas and it was like nothing happened...made it to the store, came out started fine, drove fine, then just normal cruising about 70 on said highway on the way home and boom it did it again, same exact thing...maybe a touch longer but not much...and same reaction, let off the go pedal, back to normal...I even punched it a few times as I got close to home seeing if I could recreate it but it was fine...
So what did I screw up?
The only dtc I have in forscan is for the batteries being disconnected that I hadn’t cleared out...
Old Dec 15, 2018 | 07:25 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Clearly you have an intermittent electrical problem. I would check the 42 pin connector, outside connectors for UVCH, and any other sensors or major system components you may have altered.
It is possible the problem you are seeing is not related to the maintenance, but unlikely.
EDIT: Check all of your fuses, especially the important ones for good and clean contact with their base in the panels. I have seen this a couple of times on here where loose or dirty fuses cause intermittent problems.
Old Dec 15, 2018 | 08:00 PM
MD_7.three's Avatar
MD_7.three
I agree...it’s highly likely it’s related...
I checked the 42 pin and it was good and snug, is there a torque spec for it? I didn’t want to go crazy on it as it’s just a plastic harness...
the 9 pin connecters also checked out and were seated correctly...I inspected the pigtails earlier today too and didn’t find any signs of chaffing.
I did have a thought though...what if it was my OBD adapter/forscan? I just spent another 1/2 hour after dinner and checking those connections and I was really on it multiple WOT pulls on the highway all through 4th gear and it ran better than it’s run since I got it (a testament to the oil I believe. Maybe the torque specs) but I had removed my OBD dongle after the 2nd time it happened...I had actually had something similar (though resulted in a complete engine kill, pull over, freak out, restart) happen when I was trying to use the iOS “torque pro” like app to monitor gauges and needless to say it DID NOT like my truck or the PIDs I was manually entering...I’ve had no issues ever in months of using FORScan, but the lack of DTC’s is interesting to say the least
EDIT...I will inspect the fuses tomorrow...its pouring again.
Old Dec 15, 2018 | 08:40 PM
Sous's Avatar
Sous
FTE Emeritus
Some FTE'rs have mentioned that leaving the OBD tool/scanner in the port has caused them intermittent problems. I would remove the scanner and see what happens. If the truck is still mad, check fuses.
Old Dec 15, 2018 | 08:48 PM
MD_7.three's Avatar
MD_7.three
I will admit I’m guilty of never really taking it out...the truck doesn’t sit so no worry of battery drain...and not really the area you have to worry about hackers with computers reprogramming your locks and jacking your truck/stuff.
I have (I hope) one of the OBDlink mx+’s sitting under the tree so this old Chinese knock off is out for good unless I can recreate the issue again without it.
Old Dec 16, 2018 | 03:35 PM
MD_7.three's Avatar
MD_7.three
All the fuses checked out and it hasn’t happened again since I removed the old OBD dongle...gonna hopefully chalk this one up to that as the cause...running great otherwise and started below 30* for the first time since I owned it without being plugged in on the first crank!
Old Dec 16, 2018 | 04:02 PM
Sous's Avatar
Sous
FTE Emeritus
Good news, keep us updated.
Old Dec 16, 2018 | 06:50 PM
bigb56's Avatar
bigb56
You'll love the MX....mine has been plugged in for about 4 years now with nary an issue.
Old Dec 17, 2018 | 07:40 AM
MD_7.three's Avatar
MD_7.three
Happened again this morning...no OBD dongle installed...so that's not the culprit...
Could it be a bad CPS?
It continually comes up as I search about intermittent loss of power issues...I've seen a few specifically mention it being a problem related to the windshield wipers sharing a ground and my wipers have been on during each of 3x it's happened...
The engine does not stall...the headlights, radio, dash, etc does not lose power, even momentarily...it's just a split 1 second where the WTS, SES, ans WIF lights come on and the engine loses power, but they go out almost as fast as they came on and then it's back to running like normal...
I just ran out and checked and it is the grey one...so I guess it can't hurt to just replace it anyway
Old Dec 17, 2018 | 08:17 AM
Bill Kay's Avatar
Bill Kay
It could very well be the CPS. Mine was one it the ones that had an issue with the wipers but only when they were in the intermediate position. For $25 it’s an easy swap and it’s a good idea to keep a spare in the glove box anyway. This is one sensor you want to only use OEM for. There are probably more failed aftermarket ones than good ones.
Old Dec 17, 2018 | 08:55 AM
MD_7.three's Avatar
MD_7.three
Just ordered a genuine ford one from the A-Z...$25 to rule it out beats me pulling the VC's again if I don't have to...wipers were on intermittent setting also
Sous's Avatar
Sous
FTE Emeritus
Where is the ground that is shared by the wipers terminated to on the body or frame?
Old Dec 17, 2018 | 09:16 AM
MD_7.three's Avatar
MD_7.three
Looks to me like it shares the PCM ground...I've been searching but yet to find the specific location of G104
Old Dec 17, 2018 | 03:06 PM
brian42's Avatar
brian42
Veteran: Navy
I've had the issue a few times with my LX. Truck won't start and I can hear lots of clicking under the dash. Remove the adapter, cycle the key, and all was good again.
Old Dec 17, 2018 | 03:27 PM
Jaime74656's Avatar
Jaime74656
Did you hear a loud bang or pop and have a browning of the paints when you had your sudden wtf moment? Check your car boots if one came undone it will cause the truck to go as you described power wise, another possibly but not as wtf causing is the IPR tin nut backing out, is it loose? Do you also have good fuel pressure? If not it can start to behave similar to what you described, I would lean towards electrical for the lights however.
