1995 Ford F250
Old Sep 21, 2018 | 10:13 AM
13Gage's Avatar
13Gage
1995 Ford F250
I have a 95 Ford F2 50 with the E4 OD transmission and I’m wondering if other 90 series E4OD transmissions are usable on mine. Would I just have to change out the solenoid pack and then it would work or how would that work?
Old Sep 21, 2018 | 10:30 AM
sandymane's Avatar
sandymane
What is wrong with your transmission?
Old Sep 21, 2018 | 01:20 PM
13Gage's Avatar
13Gage
Will reverse but when put in drive it won’t actually drive
Old Sep 21, 2018 | 01:40 PM
sandymane's Avatar
sandymane
From what I read the issue could be a forward clutch is bad or has a leaking seal. You should research this if you are interested in fixing it for a lot less than a rebuild. Hopefully someone else can chime in with ideas. I don't think you need to replace or rebuild it but ???? Sandy
Old Sep 21, 2018 | 08:17 PM
13Gage's Avatar
13Gage
I’ll check that when I get home but I’m wondering if transmission out of a 1997 5.4 f150 could go into mine even though it is a different motor because it does still have the e4od. I talked to a guy that I know what a Ford dealership and he said that it should be find as long as I change the solenoid pack with them
Old Sep 21, 2018 | 08:24 PM
subford's Avatar
subford
What engine do you have in your truck?
Old Sep 21, 2018 | 09:15 PM
13Gage's Avatar
13Gage
5.8 with the e4od
tonyjklh
Feb 26, 2015 09:32 PM
Dave7.3
Apr 15, 2009 12:13 AM
