Can you run Shell Rotella T4 10w-30 in a 93 f150 302?
Old Sep 20, 2018 | 10:23 PM
1994FordF-350MegaCab's Avatar
OK I've gotta do an oil change, I'm wanting to use Shell oil, Rotella T4 looks like it will work, (according to API if it's got a SN certification it's good.) Is this correct?
Old Sep 21, 2018 | 01:29 AM
Encho's Avatar
Encho
The Southernmost Mod
If that's the recommended oil weight you should be fine. API SN is the latest certification (2010) so yes, on that front you're covered.
Old Sep 21, 2018 | 07:27 AM
HardScrabble's Avatar
HardScrabble
Temporarily Deactivated
Your engine will love it but the smog ***** won't. If you burn a little oil and run a catalytic converter, might plug-up a little quicker. If it's super cold might be a little more cavitation prone. 5w40 Rotella would be a year-round choice.
If lubrication were your only problem your engine would outlast several truck bodies. Almost any modern oil is better than you need.
If your oil temp is hot enough to cook out the moisture, your oil lasts longer, engine lives longer.
Old Sep 21, 2018 | 08:19 AM
Yeah some guys were telling me that since Rotella is "diesel" motor oil it won't run I'm my truck. Maybe I'll contact Ford and Shell see if they know anything.
Old Sep 21, 2018 | 09:13 AM
My4Fordtrucks's Avatar
My4Fordtrucks
For what purpose? I have run Motorcraft oil (usually 10W-30) and filters and put a couple hundred thousand miles on several 302 engines.
Old Sep 21, 2018 | 09:27 AM
sandymane's Avatar
sandymane
I think the T designates that it is recommended for diesel. If not sure I would just use the weight you want without the T... Sandy
Old Sep 21, 2018 | 09:43 AM
10w30 is too heavy? I'm in south Louisiana, so Temps don't get to low.
Old Sep 21, 2018 | 10:08 AM
Loafy's Avatar
Loafy
I've been running Lordco Ultra Grade Diesel oil 15-40 in almost every vehicle I've owned for the past 10+ years. It is like $12 a jug. Most of everything I drive though has higher miles. Haven't touched the fluid on the pickup I just got yet as it is still golden.
Hasn't hurt the Grand Marq in 5 years... Probably wouldn't want to run a heavy oil during winter but if you have a block heater...might as well use it. I'm in the interior BC, Canada.
I'd say just run what it says to use. If it calls for 5-30 or 5-20 do so.
Pretty sure a 10w-30 is the same as 5w-30 at operating temp but 10w is quite thicker upon start...I can't remember I found a neat link worth the read again...
For a good read check out https://www.bobistheoilguy.com/motor-oil-102/
You could run 10w30 all day not hurt a damn thing.
Old Sep 21, 2018 | 10:22 AM
sandymane's Avatar
sandymane
From what I have read 10W30 is fine and I believe that is what is recommended for the 302. This subject is so debatable that ultimately you will have to decide. Sandy
Old Sep 21, 2018 | 02:48 PM
Savage19NRA's Avatar
Savage19NRA
I'm considering using T-4 also for my '92 4.9L I6. The diesel oils have a higher phosphorus and zinc content which (from what I've researched) than the newer synthetic and dino motor oils. These additives impart a surface film on flat tappet camshafts and bearing surfaces. I have been running high mileage NAPA 10-40 dino oil by Valvoline and am concerned about wiping a lobe.
Old Sep 21, 2018 | 06:28 PM
My4Fordtrucks
My ‘87 Bronco owner’s manual lists both 10W-30 & 10W-40 as the preferred oil above 0° F and my ‘89 F-150 manual has 10W-30 as the preferred oil above 0°F.
Old Sep 24, 2018 | 07:21 AM
frank5079's Avatar
frank5079
I can remember running 20W-50 in my dad's 1976 Lincoln Town Coupe back in the late 70's.....
greentruck72
Sep 19, 2016 04:03 PM
DCFord
40
Feb 28, 2010 02:06 PM
Trailblazed
Dec 28, 2007 04:53 PM
tuke
Sep 28, 2006 04:58 PM
Greentree
1997 - 2003 F150
Mar 18, 2004 07:32 PM
