96 f150 rear end swap
Old Aug 25, 2018 | 09:10 PM
torinopat's Avatar
torinopat
I found a 1990 F150 4-wheel drive at the local wrecking yard with a 355 ls rear end. It appears to have the sensor needed for anti-lock brakes on my 96 . Am I correct in assuming this is the right sensor and is there any other reason this rear end won't swap into my 1996. My 1996 is not a limited slip rear end and I'd like to rebuild the one from the wrecking yard with 410 gears and swap the whole thing into my truck. Another question this truck also has the front differential and brakes, is this the correct front four wheel drive suspension that will bolt into my 96?
Old Aug 25, 2018 | 09:25 PM
Mudsport96's Avatar
Mudsport96
Yes to all
Old Aug 26, 2018 | 10:18 AM
BigBlue 94's Avatar
BigBlue 94
90 only had rear ABS , but should work all the same.
Old Aug 26, 2018 | 10:13 PM
torinopat's Avatar
torinopat
is that to say that my 96 has front antilock? If I convert to 4x4 will I need a later front differential to be compatible with the antilock?
Old Aug 27, 2018 | 03:01 AM
My4Fordtrucks's Avatar
My4Fordtrucks
No. The wheel sensors on the front axle are located on the knuckles and the tone rings are pressed onto the wheel
hubs (behind the rotors).
Old Aug 27, 2018 | 08:27 AM
BigBlue 94's Avatar
BigBlue 94
yes a 96 has 4 wheel antilock brakes. The other part was answered already lol
Old Aug 27, 2018 | 09:00 AM
GoinBoarding's Avatar
GoinBoarding
They don't all have it. My '96 F150 has no ABS. It might have had rear at a time, but nothing up front.
Old Aug 27, 2018 | 09:54 AM
rla2005's Avatar
rla2005
Only the 1993 and later Broncos got 4 Wheel ABS. The F-series trucks stayed with the Rear Anti-lock Brake (RABS) system.
gator71
Jul 21, 2010 11:05 AM
44dwarf
Apr 27, 2009 10:49 AM
camccardell
Computer Chips & Tuners
Jul 28, 2008 11:16 AM
DJFanEighty8
Jul 3, 2006 09:45 AM
FlaBoy
Nov 7, 2004 08:09 PM
