Installed Centramatic Rings on my F450! Love them so far!
I put these on my 2017 F450 King Ranch because the balancing beads from Magnum Plus AND the brand that "Southern Tire Mart" uses did not address the balancing issues I was having with my new Toyo M608Z Tires. I could not find a shop that stocked the TAL size clip on weights, so I was stuck with either buying an assortment of TAL Weights and hoping I got enough (and the correct sizes) to do all the tires or coming up with an alternative solution. The folks at Centramatics saw my plite and offered to send me a full set of their rings to review and provide honest feedback on. I had them installed last week prior to a 400mile trip. WOW, they really work amazingly well. It's kind of funny because you can clearly hear the steel ***** rolling around inside of them when the windows are down. Sounds like your spraying water against your driveway. I had the inner dually tires balanced using standard weights (confirmed that this was ok with Centramatics), but I had all the other weights (stick on weights that were in the front tires) and beads removed. Anyhow, here is the video I posted today showcasing their installation. I will post a followup video in the days to come regarding their success on my recent trip.
Enjoy
Enjoy
Enjoy
https://youtu.be/ZxTzXDL80mI
Enjoy
wondering the same, my M920 are noisier than i like, i am looking at changing out the fronts with a more straight tread design but havent found one i really like, any ideas would be helpful.
I considered the 920s as steer tires, but the parts guy said that the 608z was a great steer tire also. They are nosier, but not so much that it bothers me. They don't seem to wonder as much as my Continentals though. I'll report back after I get some more miles on them.
Enjoy
Enjoy
I have a minor shake with my OEM F450 setup. I wonder if just putting the rings in the back would solve it. I suspect the issue is with the duals. Thoughts?
Also, why remove the weights? Wouldn't it be better to start with being close to balanced?
Finally, anyone have thoughts on centramatics vs balance master?
Thanks for the feedback on these.
I had requested that they keep the weights on the front, but because they were weight and bead balanced before, the inventor at Centramatics said to remove everything and just run the rings. The rings have enough material in them to balance out any weight unbalance though.
Glad I could help sir. Yeah, been a member here for a while.
