f250 starter motor
Old Jul 18, 2018 | 06:16 PM
herbey123's Avatar
herbey123
f250 starter motor
need a starter motor for my 1997 F250, anyone know know any good sources?
Thanks
Old Jul 18, 2018 | 06:52 PM
97-psd's Avatar
97-psd
Get one for a 2001 IIRC. it is an offset gear style starter and cranks very fast. It has a two bolt mount instead of three but it slides in no problem. The only modification was that I had to enlarge the smaller ring terminal just a bit.
Old Jul 18, 2018 | 07:44 PM
Hit Man X's Avatar
Hit Man X
Thumbs up
I did a Denso offset style. Still started my truck with one battery and no glow plugs when it was 80F out.
Old Jul 19, 2018 | 10:17 AM
knottyrope's Avatar
knottyrope
Glow plugs not needed at 70 degrees or higher
mine will start at 60 with out them but any lower it needs them
I bought a TYC new starter but found my battery cable connections were the issue and starter spins so fast
following year batteries would not crank it after a GP cycle
good read
https://www.ford-trucks.com/forums/1...ou-cranky.html
Old Jul 19, 2018 | 10:22 AM
Hit Man X's Avatar
Hit Man X
Thumbs up
I figured it would always glow unless oil temp was over a certain temperature. I had my relay disconnected even, just trying to see if this crate would start with a real weak hole.
GREAT point on battery cables. I still have crusty ones but I did clean all connections with a steel brush and a Dremmel wheel.
Old Jul 20, 2018 | 07:51 AM
knottyrope's Avatar
knottyrope
I disconnected my GPR when I had cable issues to get to work.
My tractor wont energize GP if above 70
When I looked at this truck is was 70 out and I just started it up with no waiting like I do with my tractor
Old Jul 20, 2018 | 08:11 AM
fordman67's Avatar
fordman67
I too have the tyc from rockauto.com darn affordable and does bolt on . Put on on my brother in law's truck too. That thing has not started that well in years.
​​​​​​GP on time and strategy depends on what processor you have. Older naw# models are on every time you crank. My newer tde# processor takes temp into consideration.
Old Jul 20, 2018 | 08:20 AM
knottyrope's Avatar
knottyrope
Glad to hear the TYC works well for you. For now I have a spare.
My GP is on every time I crank.
Old Jul 20, 2018 | 08:28 AM
fordman67's Avatar
fordman67
Yea and I bet your processor is naw#
Clyde Percy
Feb 10, 2017 07:49 PM
Firefighter 1406
56
Jan 5, 2017 07:21 PM
MustangMatt96GT
Mar 29, 2009 05:06 PM
O2BNMUDD
Oct 23, 2008 06:34 PM
gunwalder
Jan 8, 2004 12:59 PM
