Clutch hydraulics brand?
Old Jul 18, 2018 | 02:48 PM
Hit Man X's Avatar
Hit Man X
Thumbs up Clutch hydraulics brand?
Guess I will buy a new set since I have a reman ZF going in with new clutch.
Any brands that you guys prefer over others?
Thanks!
Old Jul 18, 2018 | 03:47 PM
867.309's Avatar
867.309
This is another question I have been curious about. I bought the pre-bled Wagner from rockauto for $40-45 or so. It's great but the pedal is a pretty stout push. Some of the other parts mention solid flywheel and this one didn't. I don't know if there are units that will give you more hydraulic advantage and a better feel to the pedal.
Old Jul 18, 2018 | 06:42 PM
Hit Man X's Avatar
Hit Man X
Exclamation
I see South Bend offers a setup. I should call them here.
Ugh. More BS.
Old Jul 18, 2018 | 06:49 PM
97-psd's Avatar
97-psd
I just use an auto zone unit and like it quite a bit. But here is the key. Don’t use the recommended slave cylinder. Do a search and double check me, but I believe I got one for an 1989 f350. The slave is bigger and has a bleeder screw. It was an exact fit and seems much more robust
Old Oct 29, 2018 | 02:51 PM
MJ79's Avatar
MJ79
What did you end up using for your hydraulics? I am also curious about the smf vs dmf. I have a smf Luk clutch, and it's time for new hydraulics.
Old Oct 29, 2018 | 04:08 PM
Hit Man X's Avatar
Hit Man X
Thumbs up
Whatever was on my rig is still there, I just flushed the system out. Did a gravity bleed, make sure to keep it full and suck out the old **** on the master first. Took about 15 or 20 min, just enough time to suck down a cold one! Moisture in the hydraulic fluid (brake fluid in this case) is what kills the seals.
green_95
Apr 9, 2017 09:56 PM
john.clark
Jan 30, 2016 12:45 PM
gatorfoot
Jun 19, 2015 06:40 AM
red bud
Aug 31, 2008 12:51 PM
rcraig
Jul 26, 2008 09:36 AM
