Hey Fellas could you look at my gallery under (53 ford update) and tell me if this is the way the brakes are supposed to look.I just put all new hardware and did one brake at a time as not to mess them up and have one to go from.These pics show the pads moving in on the bottom as like I forgot a spacer or something but I didn't see any on the bottom when I was doing the job??????? Any help Thanks DJ
Well on the pics you can definatly see that the bottoms are sucked in and would not ride flush on the drum.I replaced every thing, springs reatiners and all. I just dont know if that when I get the whole system charged and pressure in the lines if this forces the brake lining to spread out and fit the drum???
It may help a bit when you get them bled and the starwheel adjuster set. (especially the latter). The hold down pins and springs will rock more when everything else is loose. If you want to try to get a close up PIC, we will sure give them another look.
I'm with everyone else. It doesn't look like anything missing but, it looks like the shoes are too far apart. Does the drum go over it the way it is. Maybe star turned out. Wrong shoes?
Looks ok to me it is hard to see the picture. It looks like you may have 2 front shoes on it instead of a front and a back. The front shoe has a short lining and the back has a long lining. The parking brake looks like it missing.
My dos pesos: I think the shoes are on correctly - ebrake cable exits to the left toward the front - short shoe lining appears to be there. I agree, it appears the ebrake cable isn't connected. It needs to hook into the arm before anything else gets hooked up.
The spring on the bottom is incorrectly installed. It should connect the lowest holes on both shoes. Back off the adjuster enough to get this done.
Also, I've never seen two pin/spring keepers used per shoe. Only one - about the position of your bottom set will allow the setup to 'float' some.
edit: the picture 57_ford posted looks like the correct position
That's good mtflat. I didn't catch the park brake cable. It does appear to be unhooked. Also make sure it's not adjusted too tight.
I agree with the hold downs, never saw 2 like that either. Are you sure about the lower spring though? It looks correct going to the self-adjuster.
The shoes look like correct location (primary is on front).
One thing to keep in mind though is that you can't always go by the way they were. The last guy might have had it wrong too.
stepman, you got me! I even went down to the shed and dug out my original 48 axle to see how they were set up. I've seen Ford use both methods, but the spring SHOULD connect to the adjuster on this.
After looking at his picture again, I'm not sure the ebrake is wrong either. Did I write that stuff?
I bet if he removes the top pair of keepers the unit will slide up into place............?
well if it will help i uploaded some pics of my 9 inch brakes and the correct spring and the 2 mounting pin locations. to me it looks like the self adjuster assembly has been installed improperly one end of the bottom spring should hook into the self adjuster cam and one into the forward shoe if ya need any more pics or help feel free to pm me
I'm having trouble following what you are saying but the self adjuster does look squirrley as best as I can make out the PIC. Almost looks like it is entering the shoe from the backside. But I'm not sure that is possible unless you flip the right and left side parts to the wrong side. The adjuster tab that rides actuates the starwheel should be perpendicular to the wheel, not parallel as it appears.
Or am I blind and that ain't how it is. Give us some better PICs DJ, this is really getting my curiosity. Curious about the dual hold down pins too. I may learn something here but I have never seen that arrangement ever before.
Thanks for all your help. I finally just took the brake assembly to Les Schwabs and asked a good friend and rodder John to take a look at the set up. I hate to tell you all that I took it in after all you have tried to do(all of you) in helping with my problem but---- the story is old Les sold me the wrong pads and the pads I should have had are about an inch wider than in the pics. John felt so bad after me telling him this whole story he installed them right there for me and gave me 10% off.So with that Thanks Again.DJ
