Looking for a cheap and easy trans swap for my 1975 f250 with a bb 460
Old Jun 22, 2018 | 07:30 PM
1975f250bb460's Avatar
1975f250bb460
I have a c6 auto for my truck and I want another better auto to try and increase my fuel mileage and towing capacity i would like to get a trans with more gears and would hopefully bolt on or be able to buy an adapter for it
Old Jun 22, 2018 | 07:32 PM
1975f250bb460
The truck is also a 2wd supercab
Old Jun 23, 2018 | 11:18 AM
FuzzFace2's Avatar
FuzzFace2
What MPG you getting now?
460's are not known for getting good MPG.
What rear gear does the truck have and what do you use the truck for mostly?
I know over in the 80-86 side guys talk of EAOD being good if want an auto. Don't know what all is needed to make that happen as I never gone that deep into posts?
The other is a ZF 5sp stick but there is a lot of work to get on to mate up to a 460. It has hyd clutch setup you would need to deal with. And I read most need a rebuild before you can use them if used.
Or you could get a Gear Vender over drive unit that bolts onto the rear of the C6 auto. A shorter drive shaft is needed as is for the above swaps.
Dave ----
Old Jun 23, 2018 | 09:26 PM
1320stang's Avatar
1320stang
Cheap its not going to be.
Old Jun 23, 2018 | 09:42 PM
1975f250bb460
Dave ----
right now it has a c6 auto and the previous owner was getting 10 mpg and it has all stock running gear and I was looking to use it as my towing truck for bringing more projects home and I would like to keep it as an auto I already have a manual jeep that's a pain when I have to go into town
Old Jun 23, 2018 | 09:43 PM
1975f250bb460
I'm looking to go as cheap as is reasonable 300 to 500 bucks
Old Jun 24, 2018 | 12:10 AM
ranger140892's Avatar
ranger140892
Grumpy goat
I fear $500 won't even cover the incidentals you'll have to buy in order to fit a different transmission. I doubt you could do it for twice that, even if you found a free transmission.
For a 2wd C6, I'd think about a Gear Vendor's overdrive. They're not cheap either, but you won't have to replace the transmission. I think your only additional cost will be having your driveshaft shortened, or a new one made.
Old Jun 24, 2018 | 10:08 AM
5851a's Avatar
5851a
You might get a couple of mpg on the highway you may have to take it out of OD depending on load or hill's and be right back where your are with C6. Not trying to be a downer and I have had a 460 with the auto OD. Good towing mpg is not in gasser area. Just put the swap money in the fuel tank and be happy.
Old Jun 24, 2018 | 10:28 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
You're kidding, right? There is no way, NONE that you can swap in another trans for 500 bucks.
The E4OD would be a good choice, but it will likely need an overhaul, that's 1000-1500 bucks right there.
Then there's all the bits and pieces required to install it, including a driveshaft. Add another 500+ bucks.
460's weren't available w/a M/T until 1983 and then in F250/350's only. Thru 1997, F250/350's have a hydraulic clutch.
These trucks have the aerodynamics of a brick, the only way to increase highway MPG is to drive slower. No matter what you do, the city MPG will remain the same.
Old Jun 24, 2018 | 09:23 PM
1320stang's Avatar
1320stang
It'd be tough but you might find a used GV for that price. Unlikely but I've heard of it happening. You might have to buy the whole truck and part it though. Look to old motorhomes.
Old Jun 25, 2018 | 12:15 PM
Dave145's Avatar
Dave145
I'm with numberdummy. Did you by chance leave the end zeros off your figures? Because if so, then you could likely make it happen. If not, then keep saving. 10mpg is all you'll get. You've got a big block in a 4500lb rolling brick.
The AOD and EAOD are good choices, but not at all budget friendly.
Old Jun 25, 2018 | 12:38 PM
LONCO's Avatar
LONCO
I think it “could” be done cheaply. Get a used AOD or E4OD (or whatever, I’ve never been good with those #’s), including driveshaft and all associated parts, from a 94-97 F250. Without rebuilding anything and finding an inexpensive donor truck it could work. But, like people have said, the best mpg w/ a 460 I’ve ever heard of is 11-12 unloaded.
Old Jun 25, 2018 | 12:52 PM
niko20's Avatar
niko20
You can get external OD kits for a C6, but I believe you then have to get a new driveshaft (shorter one), OD kits are like $1500 on their own though just to start with.
I have a '79 with a 460 and C6 trans, I tested my highway MPG this last weekend with a camping trip. Pretty much 9.9 MPG on an 85 mile trip, averaging 60 miles per hour.
Still probably cheaper (for now) in the long run than buying a new $40,000 truck that gets 25MPG. End up paying a lot more just for insurance, truck payments, etc,..can just buy gas with that money. I guess only drawback is I'm contributing to ruining the environment, and also, less MPG means more fillups per drive, which can get annoying having to stop
Old Jun 25, 2018 | 05:32 PM
1320stang's Avatar
1320stang
Are you in California?
https://sacramento.craigslist.org/ct...625964755.html
Old Jun 25, 2018 | 07:09 PM
Blue and White's Avatar
Blue and White
For towing capability, the C6 with appropriate rear gear is very good. Maybe none better for your setup in an auto transmission. .An OD transmission may help fuel economy a bit running light. Also helps the ears with lower RPM cruising.
Agree OD can be a very expensive swap and not likely to pay back in fuel economy alone.
Also, I think 10 MPG with a 460 in a Dent is pretty darn good. Others run 6-8 MPG.
