How much torque is added when a exhaust is added to a 3.0 V6
Old 05-13-2018, 07:01 AM
Garrett Ross's Avatar
Garrett Ross
Garrett Ross is offline
The 3.0 V6 is pretty much a economy based v6 Ranger. I used to own a 1994 Ford Ranger with a 3.0 v6. It had a fairly loud exhaust (not as loud as other engines). I wonder how much more torque is added when you place a after market exhaust to a 3.0 v6. How much torque does your 3.0 v6 Ranger make with a after market exhaust?
Old 05-13-2018, 10:48 PM
85e150's Avatar
85e150
85e150 is online now
Received 1,712 Likes on 1,398 Posts
Not a lot. Opening the exhaust helps top end power in most cases. The gains are less at lower revs. What you are doing is relieving pumping losses by making it easier for the engine to expel the exhaust. At lower revs and partial throttle, the open exhaust isn't helping much. Over 4500 rpms, it may help a little.
Let's say it's worth 5 HP. At 4500 RPM, 5 HP is worth about 6 ft-lbs or torque. At 5252 rpm, HP and torque are equal, so up or down from there the gains are similar.
I'm not sure you will find actual dyno results here testing the loud muffler theories.
If you have a series of 0 to 60 or 1/4 mile times, and can duplicate the runs with and without the loud pipes you will also find your answer.
And of course, there is the butt dyno....
Garrett Ross
1983 - 2012 Ranger & B-Series
06-11-2018 04:28 PM
justin04
05-20-2004 02:05 PM
ktmguy70
1997-2006 Expedition & Navigator
13
04-25-2003 01:17 PM
mirlin1
Exhaust Systems
02-14-2003 03:27 PM
paulg
08-15-2000 10:36 PM
Quick Reply: How much torque is added when a exhaust is added to a 3.0 V6
