My 87 F150 w/300 (A/C, smog pump, power steering) is having a bad belt squeal issue. I recently did some power steering work, bled the system, and put a new Motorcraft idler pulley and Motorcraft belt on (within last 2k miles). By process of elimination (the 'ol WD-40 spray and see what stops squealing) I've determined the new idler pulley is the culprit. I spray it and the engine runs nice and quiet.
Is the pulley something I can grease? Maybe I got a defective one or maybe the "new" ones aren't quite right? Anyone out there run into this issue and have some guidance? I'm about ready to put the original on, it sqeaked a little but not nearly as bad...
Tensioner isn't putting enough pressure on the belt.
Some kind of contaminant on the new belt and or pulley causing it to squeal.
Ive learned over the years after installing any pulley to spray brake cleaner on a rag and give the belt surface of the pulley a good wipe down before installing the belt. However now days it wouldn't surprise me if you were unlucky enough to get a bad part.
Belts can get contaminated very easily. Dirt, coolant, oil, ATF, you name it. I've even able to save a belt or two if they didn't get soaked using some brake clean but usually it's too late by the time they get noisy.
The other thing on the 4.9- make sure the belt's not running against the flange on
the idler pulley. The idler arm wears, and then it doesn't align correctly.
That squeaks like crazy. Mine did it from when I got it- I changed the
idler pulley, and it started up again within a week. Changed the whole assembly,
as it was worn and not tracking right, and that cured it. I now have a spare idler pulley...
So I thought the belt had fixed the issue, but it started again shortly after. Finally figured out it was the alternator. Put a new set of alternator bearings in and haven’t had any more issues...
