Difficult to swap my '96 XL 250 doors w/ '95 XLT?
Old Apr 12, 2018 | 07:33 AM
sheepdog51's Avatar
sheepdog51
4wd Low
Looking to add power mirrors and windows to my '96 XL F250 and found some doors from a '95 XLT F150. I bought them cheap and pulled them getting as much of the wiring harness as possible. I have asked around and was told that (1.) don't even try it!!, or (2.) I needed the computer off the '95 to run the doors?? If anyone can provide some direction on this project ( even to STOP) I would appreciate it.
Thks
Old Apr 12, 2018 | 08:19 AM
Conanski's Avatar
Conanski
Physically they are a direct bolt-on, electrically you will need the controls and wiring obviously. The uncertainty comes with how much of the correct chassis wiring is present in your truck for these, and that I don't know the answer to but worst case is you have to run power to both doors from another source. The computer in this vintage truck is for the powertrain only and has nothing to do at all with electrical accessories.
Old Apr 12, 2018 | 08:47 AM
R&RFord's Avatar
R&RFord
As far as I know there is not a module involved with the mirrors or windows. Trucks with factory power door locks have a module that controls the door locks, and trucks with Ford security systems have a security module. If there is a module (and Ford was and is a fan of modules) I would think you could make this work without it.
You will need the whole wire harness or need to make your own/ splice into what you have and run it. It shouldn't be too complicated, but a wiring diagram (which I do not have) would help you.
Old Apr 12, 2018 | 09:35 AM
sheepdog51's Avatar
sheepdog51
4wd Low
Thanks for the info...any idea on where I might be able to get wiring diagrams? Ford dealer??
Old Apr 12, 2018 | 09:52 AM
R&RFord's Avatar
R&RFord
Folks on here may be able to provide a wiring diagram, and you may find some if you poke around the forum with the search function.
You can buy access to the workshop manual and electrical vacuum troubleshooting manual which includes the appropriate diagrams here. In the past I have had luck getting a wiring diagram from a service tech.
Or find a paper copy for sale second hand.
Old Apr 12, 2018 | 10:34 AM
ifrythings's Avatar
ifrythings
There is no module ( unless you want the security module but lets not go there), there is a separate harness that runs from door to door on the firewall that you need and that will plug into the dash harness, you will also need the 2 circuit breaker ( square metal cans) to fill the missing spots in your fuse box, this is a very easy swap to do.
As for wiring diagrams, looke here ( make sure to select wiring diagrams and not tsb’s) BBB Industries- Premium Alternators, Starters, Power Steering Products | TSB's & Wiring Diagrams
Old Apr 12, 2018 | 12:47 PM
NotEnoughTrucks2014's Avatar
NotEnoughTrucks2014
Wiring diagrams can be found here.
BBB Industries - Technical Support & Resources
Now, the doors will fit, but you already have a big problem in that you did not get the complete wiring harness for the doors. You probably found the disconnect for the passenger side door in the kick panel, but the harness out the driver's side door has no disconnect, save for the one in the passenger side kick panel. The harness runs behind the dash along the cowl. It is a separate harness, but you must remove, or loosen the entire dash to get to it.
You probably could fabricate something of a harness by matching colors and extending wires and you likely could find a more accessible run, but this will take some research and effort.
Old Apr 12, 2018 | 05:41 PM
Diesel_Brad's Avatar
Diesel_Brad
The harness runs behind the dash just under the windshield. You have to remove the entire dash to run the harness
dixie460
Nov 9, 2015 06:12 PM
Tripodme
Mar 24, 2015 02:35 AM
bigrigfixer
1983 - 2012 Ranger & B-Series
Mar 31, 2004 11:12 PM
tingve
1978 - 1996 Big Bronco
Jun 5, 2003 12:04 PM
01rangerrick
Aug 3, 2002 10:14 AM
