glow plug harness broke of level with sleeve
I still have all of the glow plugs to do because i haven't been able to get the harness parts that sit in the sleeve.
not to sound whiny or anything but if anyone has some ideas to try that would work to get the harness part off of the glow plugs that would be awesome.
The things i have tried are the 18 gauge wire trick to no avail, then i have tried running a screw in and that hasn't helped.
any help or suggestions or even if someone lives in the Spokane WA area that maybe able to take a look that would be great.
Thanks Matt
The #2 I ran a screw in about 2/3 of an inch and wiggled and wobbled it and got it to move some then blasted it with the PB blaster stuff again wired a few minutes then yanked on the screw and it popped out.
The #4 and #6 I did exactly what you mentioned about grabbing the wires and they popped right out. now #8 I'm having a hard time getting to with anything and it looks like the same as the #2 did broken flush with the sleeve or whatever its called and not a whole lot of room to get to it. I did pull the degassing bottle out to give myself some more room but that really hasn't helped.
I am so close but yet so far away from being done. I thought about the inner wheel well and pulling that off to get a better view but that looks like a nightmare to do with all the plastic clips that go into it and all the little bolts.
Thats where I am on my progress. Again I appreciate the help and the ideas.
Any ideas would be great.
Thanks Matt
Thanks Matt
Use a meter & OHM out the #2 glowplug wire in the harness from the pigtail plug to the plug on the module. If you don't find a chafe or issue with the harnesses than the only thing left is the glowplug module.
Great job on discussions and I like the specifics on the tools and writing, accompanied with pictures.
I've been pulled away due to a two yes dual "commode" (toilet) wax ring failure and resultant Emergency in my house. Yeah, two at once. Leaving just the third working & usable. Tile, sub-floor, and grouting and details i won't bore y'all with. So I'm away from completing my PSD project and "tool". However I expect to get back to it Friday after work.
In the meantime, I've purchased and received a video- camera "endoscope" to see (& possibly record) deep into the "underworld" below the removed oil rail to verify what's going on. And get the last two Harness Plugs removed. The new Standpipes go in, new Dummy Plugs, Glow Plugs, Harnesses and back together. CRRRRrrrrank!
The "tool" will be in testing with the endoscope to observe and verify no metal parts enter the engine.
Thank you very much for the excellent viewpoints and volleys. That's what this is for!
More soon!
best regards,
Christopher
More soon!
best regards,
Christopher
