easy way to remove bushings
Old Feb 1, 2018 | 05:01 PM
lilorbie's Avatar
lilorbie
some of you may already know about this. but i just found out about it. i am putting a rear sway bar on my 67 f-100. i am using the rear sway bar from a 86/88 Ford Bronco 2. the frame rails are the same distance apart 34 inches out side to outside. any way the bushings from my rear bar are junk. the easy way to remove them. get a hole saw just a little bit smaller than the bushing. chuck the hole saw in a drill press and Slowly drill out the bushing. i would have used a press ,but i don,t have one. maybe this will help someone.
Old Feb 3, 2018 | 12:44 AM
GaryKip's Avatar
GaryKip
Good to know, thanks for sharing.
Old Feb 3, 2018 | 06:16 AM
lilorbie's Avatar
lilorbie
GaryKip no problemo. just thought it might be of help to someone.
Old Feb 3, 2018 | 12:14 PM
ultraranger's Avatar
ultraranger
The stock rubber bushings were junk on the '79 full-size Bronco rear swaybar I got to put on my '69 F100. I replaced them with new polyurethane bushings. The '78/'79 Bronco rear swaybar diameter is 1-1/8".
Old Feb 5, 2018 | 04:11 AM
GaryKip's Avatar
GaryKip
You should post this in the "Shop Tricks & Ideas" Stickie note
ranger140892
Jun 24, 2019 04:10 PM
robjs111
Ford Truck Parts for Sale
Aug 13, 2013 12:01 PM
crazy96863
Aug 3, 2013 03:42 PM
19-kilo
Dec 2, 2011 08:24 AM
sgrol
Apr 21, 2006 05:56 AM
