NEED HELP 1967 F600
Old Feb 1, 2018 | 04:31 PM
Camman33's Avatar
Camman33
NEED HELP 1967 F600
hello everybody, first let me start with giving a big thank you to all the members, I have learned a lot about my Truck and the do’s and donts, I’m in the process of fixing up my dream Truck, got it running and replacing parts that I no are bad, one of the problems I’m having is the radiator..... this one leaks and I can not find a replacement. The motor is a 330, also finding radiator hoses is almost impossible as well. Any info would be greatly appreciated, I’m in NE Ohio
VIN f60cca78439
Old Feb 1, 2018 | 05:15 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
VIN: F60CCA78439
F60 = F600 (gas).
C = 330 2V Medium Duty FT engine.
C = Oakville Ontario Canada Truck Assembly Plant.
A78439 = 1967.
Suggest posting in the LARGE TRUCK forum, as you'll find more members that own like trucks.
Radiator is the same 1967/78 F500/750 330 2V M/D; 330 2V H/D; 361 & 391, but I don't know if anyone makes a replacement. Try NAPA
If you cannot find it, a radiator shop can re-core your original.
NAPA should have the hoses, but if not...
> Green Sales Co. in Cincinnati OH has the largest stock of Ford obsolete parts in the world (800-543-4959). <
Old Feb 1, 2018 | 05:52 PM
Camman33's Avatar
Camman33
F600
Thank you, didn’t know where to post, tried NAPA for Hosea, they where I correct, will loook up differnt years for radiator, thank you
Old Feb 1, 2018 | 06:16 PM
Tedster9's Avatar
Tedster9
Another thing you can try if worse comes to worst is bend up a coat hanger at your truck in the length and routing needed and take that with you to NAPA or anybody with a good selection of different hoses hanging on the wall. Just match something up that's close.
Old Feb 1, 2018 | 06:57 PM
NumberDummy
1964 F500/750 330 M/D//330 H/D & 361/391; 1965/72 F500/600 330 M/D:
C4TZ-8260-D
.. Upper Radiator Hose (Motorcraft KM-200) / Obsolete
NOS PARTS LTD in Waxahachie TX has 1 = 972-937-2201.
MILLER OBSOLETE PARTS in Binghamton NY has 1 = 607-722-5371.
MCDONALD OBSOLETE PARTS in Rockport IN has 1 = 812-359-4965.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 1 = 800-476-9653.
C4TZ-8286-H .. Lower Radiator Hose (Motorcraft KM-212) / Obsolete
NOS PARTS LTD has 1.
MILLER OBSOLETE PARTS has 1.
NAPA should be able to cross the Motorcraft part numbers over to the brands they sell.
Old Feb 2, 2018 | 03:38 AM
Camman33's Avatar
Camman33
C4TZ-8260-D
WOW @numberdummy, your the man! I cross referenced those part numbers on Napa and got found the correct hoses
upper- NBH 7244
lower- NBH 7485
now to find a radiator or get this one worked on
Old Sep 17, 2020 | 02:05 AM
Robclark's Avatar
Robclark
upper- NBH 7244
lower- NBH 7485
Thanks for posting the part numbers. Actually the numbers are correct but the nomenclature is backwards,
Upper is NBH 7485
Lower is NBH 7244
Either way, I needed them both and this was a lot of help. Any time you buy a part for your 1967 F600 please post the part numbers. Again, Thank You So Much
86-IDI
Feb 23, 2019 05:52 PM
johnnyidaho
Jan 24, 2019 03:02 PM
Camman33
Large Truck
Feb 3, 2018 03:17 PM
tacurl03
Feb 27, 2017 09:48 PM
Dumpster Villard
Apr 8, 2004 09:22 PM
