Adding Power Passenger Seat ??
Old Oct 24, 2017 | 12:21 PM
SuperDad's Avatar
SuperDad
I bought a used 2006 F-250 Power Passenger Seat track and motor. I'd like to ad this to my 2000 Ex which only has power drivers seat in it. Does anybody know if the wires are already under the carpet on the passenger side??
Old Oct 24, 2017 | 06:24 PM
SuperDad's Avatar
SuperDad
anybody know??
Old Oct 24, 2017 | 08:08 PM
pirate4x4_camo's Avatar
pirate4x4_camo
I do not recall any connector for my 01 so I looked it up, factory wiring diagram doesn't even show a power passenger seat option so I looked at the 05 wire diagram and it doesn't show it either. The 05 does have wiring for a driver memory seat however.
That said, here is the diagram so you can build your own wiring harness.
Old Oct 24, 2017 | 08:09 PM
pirate4x4_camo
Connector pin out.
Old Oct 24, 2017 | 08:33 PM
Misky6.0's Avatar
Misky6.0
I have power adjustable passenger seat in my '05, no memory but it is 6-way adjustable exactly like driver seat:
* seat moves fwd and backwards
* front of seat moves up and down
* rear of seat moves up and down
the tilt of seatbacks is manual lever to unlock to move it..
Old Oct 24, 2017 | 09:59 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
I added the power passenger seat to my '01 from an '04 F350. I used the plug from the heated seats that was already there to power the motors on the power seat. Had to move two pins around in the plug and it was all done. Works great, and I am using the fuse for the no longer used heated seat.
If you get both sides of the plug off that 06 seat you got, your task is sooooo much easier. Just splice power & ground into the wires on the plug from the donor truck and you are golden.
Old Oct 25, 2017 | 05:53 AM
SuperDad's Avatar
SuperDad
Thanks that will help!
Old Oct 25, 2017 | 11:30 AM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
Here is how simple it was for me:
I had to move the wires in my fingers over to different pin holes to match the power and ground for the '04 seat. Just a ground and a fused hot on the truck side. The harness connector for the '04 power seat is on the right.
You could also tap into the power seat on the driver side, and run about 3' of wire under the carpet to the passenger side, then splice those into your plug. This way, you would have the feed fused as well.
You will just have to ignore my rusty junkyard seat frame there...it works!
WisconsinBill
Mar 27, 2017 01:54 PM
Project-55
Nov 14, 2013 09:53 PM
c_hohensee
Feb 19, 2013 11:18 AM
kpriddy
Dec 2, 2007 12:54 PM
kynnhoj
Escape & Escape Hybrid
Apr 15, 2006 10:34 AM
