Rear signal and brake lights dim front flash fast
Old Oct 17, 2017 | 11:04 AM
kc2usa's Avatar
kc2usa
Rear signal lights dim and front signals flash fast when the brake is applied. Also the dome lights dim and brighten as the signal flashes. Anyone else ever have this problem? There seems to be a short to ground but I'm not blowing any fuses. Any ideas?
Old Oct 17, 2017 | 12:18 PM
Misky6.0's Avatar
Misky6.0
Sometimes, a dual-element bulb will have 1 filament break and land on the other filament - and back-feed (depending upon which end breaks).
The filament acts like a resister and will (often) protect a fuse by limiting the current.
You have a fun isolation task ahead
What happens when you turn on the 4-way hazards?
Try with Left and right turn signals to (hopefully) identify which SIDE the problem is on.
* with parking lights on
* with parking lights OFF
* with headlights ON
* with high-beams ON
with ALL lights OFF, put something on the brakes, try left, right turn signals - and then with 4-way hazard, hopefully they behave differently.
The BRAKES will help ID if the problem is FRONT or BACK, if the problem is the same WITH brakes - it's the back, if it DOESN'T repeat with brakes it's FRONT.
Depending on the model year, you may be able to swap the flasher with the 4-way (or another one) to rule out the flasher. Typically, the flasher is easy/cheap and having a spare (if you buy 1 but don't need it) isn't a big deal.
Old Oct 18, 2017 | 12:55 PM
kc2usa's Avatar
kc2usa
I think I'm past what your suggesting at this point. I've been through every bulb on the truck. No loose or dangling filaments. I disconnected the wiring harness below the master cylinder and I no longer have the short to ground in the rear of the truck. I suspect it may be a wire on the harness on the tilt column. Stay tuned.
Old Oct 22, 2017 | 03:50 PM
EX40's Avatar
EX40
Do your front signals work for intended side? I had the same issue when I broke a ground changing my fuel pump. There is a ground on the harness driver side rear on the frame rail. My lights were dim, fast flash when brake pedal pressed, and signals worked for opposite sides in front.
Old Oct 22, 2017 | 04:08 PM
metru's Avatar
metru
i posted pictures of the ground in the rear for the rear lights if it may help i can link it
Old Oct 23, 2017 | 09:43 AM
kc2usa's Avatar
kc2usa
Yes everything works normal until I step on the brake. I have been over every ground on the truck because that's what it acted like. Here's what makes it tough. It doesn't do it all the time. I haven't had a chance to work on it further so I will let you know how I make out.
Old Nov 27, 2017 | 01:38 PM
kc2usa's Avatar
kc2usa
It's fixed! It was a ground as it acted. There was a partial body collapse in the left rear that cut both ground wires to the rear lights. That explains why it was intermittent for a time.
michael69
Jul 15, 2019 10:37 AM
PRUSue
Sep 25, 2013 11:38 PM
wulleebullee
13
Oct 26, 2011 09:19 PM
78_f150
Jun 4, 2010 11:36 PM
lilpig88
Electrical Systems/Wiring
Jan 24, 2003 07:49 AM
