Custom dash cluster 2002 to 2008
https://www.ford-trucks.com/forums/1...dash-swap.html
https://www.ford-trucks.com/forums/1...oo-2008-a.html
https://www.ford-trucks.com/forums/1...015-build.html
Well if you look at the reads above you will see what can be done as some of the folks that have done it have chronicled in there threads. The biggest challenge your going to face is making your gauges work on the cluster and the controls for radio heating/ ac /defrost etc so adding wire and what not to meld things or to run new wires to make some items working work
The one thing you will need though is a donor dash with the cluster, if you could find a wrecked truck and grab the dash and as much of the other stuff you think you may need ( harnesses, fuse box, steering wheel and column unless your keeping your old column and steering wheel ) that I think will help a lot
But I would give those threads a good read and ask some questions about items that are crucial that you need to have from a wrecked truck or donor truck to the guys that are doing it or have done it, I am sure they'd be happy to help answer them
