Dana 44 vs 60-3
Old Sep 4, 2017 | 10:18 PM
john jamieson's Avatar
john jamieson
Dana 44 vs 60-3
So What are the differences between the two? I thought my truck had a 44 but the cover looks more like a 60. The door plate says it came with a 9" and that is not what it now has. I didn't see anything clearly mentioned in the shop manual.
Thanks. john
Old Sep 5, 2017 | 05:53 AM
ihcc104's Avatar
ihcc104
There should be raised numbers with either a 60 or 44 on the top of the casting toward the front.
Old Sep 7, 2017 | 07:28 AM
john jamieson
I haven't been able to find any numbers like that. I do have stampings on the passenger side of the tube: "456 A", "2809 4", and "4 46B2". I haven't been able to match them with on-line references since most seam to only go back to '67.
Thanks.
john
Old Sep 7, 2017 | 01:58 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
AXLE code stamped on the 2nd line-far right of the Warranty Plate, riveted to the left door face below the latch.
1966 F100 could have a Ford 9" or with Limited Slip: Dana 44, Dana 60.2 or Dana 60.3.
The Dana 60.2 & 60.3 are not Dana 60's, as 60's were only installed in F250's.
1959 thru today: If the AXLE code begins w/a letter: Limited Slip. If w/a number, no Limited Slip.
Old Sep 7, 2017 | 08:19 PM
john jamieson
Thanks ND. You deciphered my warranty plate in the past. What I am wondering is what are the physical differences between the 44, 60.2 and 60.3?
Old Sep 8, 2017 | 09:27 AM
NumberDummy
08 = Ford 9" Rear Axle / 3.50-1 / 3,300 lbs. Rear Axle Capacity.
Old Sep 9, 2017 | 09:39 AM
Amphihauler's Avatar
Amphihauler
ND, I understand that the breaks and axle bearings and seals are the same as the 9" in the 60.2 & 60.3. Is that why you say it's not a Dana 60? Smaller axle shafts I assume. Any info on the shaft size or spline count? I have a Dana 60.3 I may rebuild to replace my 9". Would the 9" axle shafts be the same as the 60.3 by chance?
Old Sep 9, 2017 | 10:46 AM
NumberDummy
Originally Posted by Amphihauler
ND, I understand that the brakes and axle bearings and seals are the same as the 9" in the 60.2 & 60.3.
No.
The Dana 60 was only installed in F250's that have 8 lug wheels on a 6.50" bolt circle. F250 brakes are larger than F100's.
Ford 9 inch, Dana 44, Dana 60.2 & Dana 60.3 were installed in F100's that have 5 lug wheels on a 5.50" bolt circle.
Old Sep 9, 2017 | 11:16 AM
Amphihauler
Thanks, still wondering how unique the axle shafts of a 60.3 are or if they are similar to the 9" like the brakes.
Old Sep 9, 2017 | 11:38 AM
NumberDummy
The 11" x 1 3/4" rear brakes are similar: 1948/52 F1; 1953/67 F100, regardless of what rear axles these trucks came with.
1964 F100 2WD was the first to have self adjusting brakes. Self adjusting brakes for F100 4WD's introduced in 1967.
Jam21
Mar 13, 2011 05:05 PM
manunley
Jul 16, 2007 09:15 AM
RacerRick
18
Jul 27, 2005 02:01 PM
kai123
Mar 17, 2003 07:50 AM
Eagle131
Offroad & 4x4
May 25, 2002 03:04 PM
