2000 ford expedition brake pedal goes to floor but changed everything brake related
Old Jul 26, 2017 | 03:01 PM
Kingpin773's Avatar
Kingpin773
hi i have a 2000 ford expedition that has a brake pedal that is going to the floor. we bled the brake lines several times, changed the brake lines, the calipers, the master cylinder, brake booster, and even put a different abs pump in. these brakes still go to the floor. i heard that maybe an axle bearing or something has something to do with it... I cannot find that website talking about that topic again. so i am making this thread hoping someone can help.
Old Jul 26, 2017 | 03:16 PM
alloro's Avatar
alloro
Did you install the calipers on the correct side? Some calipers can be installed on either side. If you do the bleed screw ends up at the bottom of the caliper rather than the top so you can never get the air out.
Gordesky Mco
Dec 12, 2016 02:57 PM
fordex007
Oct 23, 2015 11:49 PM
Diesel Reaper
Apr 25, 2012 08:47 AM
V10'nr
Mar 24, 2008 10:57 AM
